FSB is not showing what it is said !
firubbi
Post by firubbi »
hello there,
*my mobo model is " asus p4t...E763
http://www.asus.com/mb/socket423/p4t/specification.htm
*i'm using p4 1.4 processor(400Mhz system bus,423 pin package,box.....
*Ram - RD400 Mhz, 512Mb
But the problem is on Bios setup "cpu front side bus frequency = 100 and max 120!!!
it should be 400Mhz... So is there anyone using the same mobo can tell how this happen!
Nestor
Post by Nestor »
Í'm not an expert on this, but I think you are doing the exact same mistake than myself, cos you think these speeds mast match, but in fact, they have to be the exact half of real speed on your CPU.
Chek it out, or somebody else please tell us if I'm wrong. Anyway, I've given you a point to search.
aMo
Post by aMo »
On Intel Mobo's there is not a doubler of the FSB like on Athlon based mobo's (i.e. 2x133 = 266), but instead it quadrouples the FSB speed (4x100mhz = 400mhz).
So 100mhz should be right afaik..
firubbi
Post by firubbi »
maybe you are right aMo. i post a mail to asus but they (a china guy) wanted to know which bios is showing 100Mhz? and i lost it :???: ... maybe its not so important but then again i'm missing 400Mhz. my friend both a digidesign 002 and we made a pc for that over a pc shop. and he boutht a 533Mhz mobo,2.4 533Mhz processor and ddr 333. and i saw that 533Mhz fsb on bios....anyway thanks guys...if anyone got anything plz reply.
<font size=-1>[ This Message was edited by: firubbi on 2003-09-11 13:54 ]</font>
Don't worry, sleep tight :smile:
As aMo says, the 100MHz is a base frequency. RAM & CPU frequencies are multiples of that.
100 & 133MHz still are FSB standards, in these GHz times!
PS. If you can set any freq. in the range 100-120MHz in your BIOS, setting to higher value is one way to overclock the machine.
firubbi
Post by firubbi »
overclocking may cause problem to audio recording :???: what do you think Atomic?
