hello there,
can you help me installing "Final Liza 3"
it has 2 file
1.Final Liza.dev
2.Final Liza.pre
please tell me where to put this files.
thanks a lot.
how to install Final Liza 3
spoimala
- Gordon Gekko
- firubbi
legros/spoimala,
i"m asking you again. the dev file is ok i got final Lisa from sfp BUT can't get any preset!! i put that pre file to preset(also do you remember that program Kick me? that has got the same problem--- can't get any preset. i also tried *load file and select that file from final Lisa but ...can't get any)...
if you guys have time:) can you spend a little here.
thanks a lot.
thanks a lot.
- Mr Arkadin
borg
i don't really know about the final liza preset list... this more a general hint, at least this is on mac:
if you try to load a preset file, be sure to widen the preset window and drag the symbol with the two arrows to the left (if i'm not mistaken). i'm not on the DAW right now, so, this is out of memory. you should create a new bank in the left preset list (in SFP) and then import the bank from the preset folder.
i hope i haven't talked bs. i'll check later or someone can verify/correct.
andy
the lunatics are in the hall
kimgr
kimgr
