Just curious, but is 10 Master verbs good for a PowerPulsar?
Basic Pitch
Greetings all,
Well after reading a bunch of threads in the archives it seems the standard bench mark around here seems to be masterverbs. I have a 15 DSP PowePulsar in my box which consists of the following:
- Asus A7N8X nForce2
- 512m Crucial CAS2 (normally a gig but I borred some for a 2nd PC atm).
- Athlon XP 2500+
So I decided to load them up and see what I can manage, I ended up with 10 Masterverbs before I got a "Not enough DSP Power" or something to that extent message..
Though while looking at the DSP bar it was only sitting around 70% in terms of how much the yellow bar was in considering a 1-100% ratio..
So is that any good? Just curious is all..
Cheers!
- Athlon XP 2500+
Cheers!
King of Snake
Guest
Basic Pitch
Well here is a general of whats set up in SFP, though im at work ill do my best to remember
- Mixer: 2446?
- ASIO2 16 Source
- 8x Multi S Effects inserts
- Sequencer Midi Source
- Creamware Midi A
- Analog Source
- Wave Source
- Analog Dest.
- Wave Dest.
- Asio2 Dest.
- 10x MasterVerb
To the best of my recollection that encompases the entire .pro
Cheers!
- Mixer: 2446?
- ASIO2 16 Source
- Creamware Midi A
- Analog Source
- Wave Source
- Analog Dest.
- Wave Dest.
- Asio2 Dest.
- 10x MasterVerb
Cheers!
spoimala
Hmmh... I got "only" 9 and when trying to add one more, I get
"A capacity limit of your dsp cards has been reached. The specific cause is: Not enough DSP memory: cannot connect PC Master 3k delay.Tap1 and DLEXTM0.RI"
Weird. Maybe something is broken in my card? I've got this DSP memory thing before.
Basic Pitch
- astroman
