Well I was curious about the pro one so I decided to download the demo, now typicaly I have always used Pro52/53 for my Prophet type sounds, and have always adored the NI Pro52/53, so I just had to see if the ProOne was as good or better, now keeping in mind these are not the same device there are going to be differences but they are targeted at the same synth line and sound.
The 1st part will be a basic trance type lead playing a simple pattern, the 1st bar will be the ProOne followed directly by the Pro53, there is no break in sound they play straight through, the 1st part is effected, the second pert is dry.
In my opinion I found the synths to both sound rather good around middle C, clearly better sounding with the patch effect running, but decent dry.
Now the 2nd part of this file is a simple single note playing I think 3 notes moving down the scale, in a lower octave than previous, this is where you really start to notice the biggest difference, the CW synth hangs in there for the most part and plays the single note fairly true, where as the Pro53 pretty much chokes and dies, the sound is harsh and ugly, pretty much not usable..
So for this test I used stock patches, I found two that were as close as I could get with out creating from scratch, but clearly the ProOne has a more realistic and fatter analog sound..
You be the judge
