Can't see my new hard drive
- Nestor
It's amazing, I'm having the exact same problem right now with my old IBM, everything is alright, but the drive is not seen in My Computer...
This is what I'm doing: I've donwloaded a DOS little program from Seagate that allows me to format the disk without being in Windows, so I formated it, and then reinstalled it. I'm waiting till the formating in NTFS is finished, and then I can tell if I succed or not to see it again.
I think this is a good way. I'm pretty sure Wester Digital has some similar programs to download from their web. Try it out... and good luck.
Sorted....many thanks. I tried a search on the topic in the forums but didn't find what I was looking for....I'd better fine tune my search skills.
Did as you suggested Petal....and Will......and Spirit........and Nestor. I'd forgotten some of these basics, so thank you all.
Now, if anyone can tell me where my car keys are I'll be most grateful.......
Where's my car.............?
<font size=-1>[ This Message was edited by: Mikka on 2003-09-03 05:07 ]</font>
Shayne White
Which OS are you running? If you're using Win98, you have to split the drive up into several partitions because FAT32 can only handle 32GB per partition. If you're using XP, XP can partition and format the drive with NTFS right off the CD. I don't know about W2k, I don't remember how that worked.
I formatted a 180GB HD from WD and it works fine. I'm using XP SP1....
Shayne
Shayne
Shayne White
P.S. No HD will show up in My Computer unless it's been formatted. In W2k/XP, there's a Disk Management Utility in "Computer Management" in Administrative Tools. (Storage --> Disk Management) From there you can partition and format drives. In Win98, you have to run FDISK from DOS, I believe. There might be some way to format the disk from Windows, but I don't have Win98 anymore and I can't tell you.
Shayne
Shayne
