Mod II: sequencer modules tip
A space for learning and studying the Scope environment and music-making in general.
bosone
Post by bosone »
I originally posted this in the modular section, but probably this is the right section...
i found a somewhat simpler way to work with mod2 setp sequencer, gate, arpeggiator module. they have normally 32 pattern and the pattern are usually selected by the patter seq module (the one with play/stop button). using the patter seq module is a pain, since it does not interact with your sequencer.
so that is the trick: assign a CC to the pattern number selection in the control sequencer 1,2 B1, b2, gate seq or whatever.
now from you host (sonar, cubase, etc) you can recall the pattern simply with a CC change. much easier!!
