Ahhhhh, what a relief. I can now record MIDI without occasional crackle, clicks and pops.
For a long time, I though the problem was USB, Underpowered PC, RAM, the weather or even Dolly Partons fault, but the light of wisdom have now left me in totally happy MIDI tightness with no creative interruptions (sort of).
well, to the point... If your DAW of choice is Cubase SX or Nuendo, your OS is Win$2000 or XP, and your MIDI connections inside the app have the word [Emulated] in square brackets after its port name, AND (phew)you are having MIDI timing or stability problems, here MIGHT be the solution for you:
Go inside the root folder where Cubase is installed is a folder called "MIDI Port Enabler". Copy the file in there to the root folder (eg. "C:program filessteinbergCubase SX")
Now when you boot Cubase next time every MIDI connection on your system is available, not just the Directsound ones. The trick is to disable all emulated port (in the device setup/DirectMusic dialog...set show to "no"), and enable your original, nonemulated port in the Windows MIDI dialog. (set show to yes). From now on you are not going through M$ crappy DX layer (why is this made so anyway?).
Maybe I am stupid, but I didn't noticed this, even though it mentioned it the installer, and there is a text document descriping the problem in the root folder, maybe you didn't consider this a problem.
Hope I helped some poor people out there.
Happy sequencing.
By the way, I use a Emagic AMT8 MIDI interface.
							Done with clicks and instable time when recording MIDI
				mythalethe
				Counterparts
Steinberg have an article about this in their knowledge base (doesn't particularly add any more than what Thalamus said, though):
http://service.steinberg.net/knowledge_ ... enDocument
Royston
Royston
