I don't yet know what the difference between these two is. Could someone explain that to me?
<font size=-1>[ This Message was edited by: Ashkenazy on 2003-08-19 10:09 ]</font>
						What is the difference between Scope SP and DP?
As aMo mentions, SP contains all devices from CW and can afaik only be bought with a Scope card.
DP is kind of a low-level version of SFP, it looks similar but loads smaller elements, atoms. The project is not a production but a development environment, in which you can create devices & other neat things that can be used in SFP. Here's a small example of DP. And even if you have the money for it -it's very expensive-, you'd still have to convince Creamware that you'll be using it properly.
Also, there's some other topics on the subject in this forum, check them out!
