New Sound Designer Tool : Harm Gen Synth (non-Scope)
Re: New Sound Designer Tool : Harm Gen Synth (non-Scope)
Version 1.4 is finished:
-4 instruments with 16 partials each (mergeable)
-Preset saving and loading
- Keyboardzones assignable to each instrument
- Parameter automation
- Flanger/Chorus/Phaser/Reverb/2 different Filters/Multitap delay with 4 write and 4 read heads, ping pong possible
and of course loading/editing of resynth files. Download link follows:
https://gum.co/SeaBn
VST,VST3 and Standalone version.
Keyboard shortcuts:
# increase max partials by 1
$ increase max segemnts by 8
[ mark left border of segment selection
] endmark right border of segment selection
0 reset (level = 0) selected partial/segments/all
X reverse selected partial/segments/all
homeKey select first partial
endKey select lst partial
pageUpKey select next higher partial
pageDownKey select next lower partial
P set max partials to selected
S set max segments to selected partials or all (omni)
@ set target mark
+ set zoom mode show only 3 or less partials
leftKey shift sector view left
rightKey shift sector view right
C toggle contour mode
L toggle loop mode –mark to endmark
A toggle omni mode
. toggle segment's contour point (right mouseclick)
/ toggle Shruti mode-> ignore note-off,
_ toggle spread mode (also available on part screen)
Z undo partial or omni changes to start-up status
U unmark all
- unset zoom mode
upKey zoom-in sector view
downKey zoom-out sector view
F1 set lower range of keyboardzone
F2 set upper range of keyboardzone
F3 unzone all instruments
1-4 select instrument
@ set target mark
A toggle omni mode
U unmark all
- unset zoom mode
I have updated the Synth (correcting some minor errors) to the last 1.4 Version.
Next Version (2.x) will have the Resynth included.
More Gui Screenshots
You can see the routing window for the 4 Spectral engines. Below are the Keymappings and drum pad design tool for all engines (4 spectral synths and 4 samplers). Left is the usual Solo/Mute control and on the right the panning controls S: shape of the LFO, R is speed and P is panning width -1 - 1
You can map any of the instruments to any range of the keyboard. Additionally you can also tune each instrument to a different key.
As a goody: you can design you own color for each instrument.
looks cool starts to take shape man
http://www.oceanswift.net
Music
Music
Now with extended view, show all LFO/ADSR/Filter and wavetable activity - yes each partial can be used to generate WT sound.
You can also switch from 8x2 to 4x4 pad layout.
- mapp21.png (78.98 KiB) Viewed 8273 times
are you planning also a vsti build?
Music
Music
Yes, there will be a VSTi and and standalone version
Just for fun: wavetables in space:
https://youtu.be/eTYK_rIl6p8
This is really developing in a cool direction. Nice work DragonSF!
I'm working now with OceanSwift and the VSTi is getting exciting.
My "cool direction" comment now has new meaning. Looking forward to this now more than ever.
