widy wrote:pwhitmaker wrote:According to the website the 5.1 should be able to download the 9:th of dec, but its still not there?
maybe here
ftp://sonic-core.net/software/scope_5.1_x64/
lg widy
Thanks Widy. Downloading now
maybe here
lg widy
stardust wrote:Hallo Holger und SC Team,
nice to see you alive and kicking.
Even nicer to see you reading the user forum.
I was willing to thank you for the new version but you made me hesitate with your latest post.
So what is this 5.1 2709 now about ?
For XITE:
Are there any improvements over 2617 from last year ?
Could you be so kind to be specific what the differences are in the XP 32bit version?
Is the VSTIM/XTC mode now usable in XP 32bit with better load distribution and manual DSP assignment ?
Is the only difference the introduction of the W7 64bit support ?
Are there any bugs fixed in XP 32bit version ?
For PCI:
What is the difference between 2617 and 2709 in XP 32bit ?
I am really not clear whether I should go for 2709 or not in XP 32bit, so it would be nice to know if I can expect improvements with an update.
Thanks for reading and an answer.
kind regards - stardust
Of course, I can ask my boss to double my salary "becauseIworthit" .sonicstrav wrote: There have been some comments regarding prices etc. SC can charge what they like and they have a unique product developed by a very small development team that need to charge those prices to make it worthwhile as a business - I'm sure they are not making a fortune out of it.
That´s strange, S/C told that STS sampler now has not memory limit, only limited by PC. If it´s a real 32bit will be limited to 4GB and that should be appling a LAA tool to the exe.ARCADIOS wrote:scope 5.1 works fine.....
EXCEPT... it is not 64bit. it just works on 64bit windows.
XTC mode only works in 32bit daws![]()
as you can see in task manager it is ...scope.exe32
we have to wait i guess for a real 64bit application.
uh, I can't find the ModIV manual into FTP folders... where is it????XITE-1/4LIVE wrote:Check the ftp. site for some new goodies.
Modular IV Manual is available, and for the x64 XITE-1/Mod IV guys, you need to copy over all of the new modules and VST Clock Folder.
Old folder copy/paste won't work if you're coming from 2707/08.
Ankyu Julian.....
it works in 7 64bit.bosone wrote:ARCADIOS wrote:scope 5.1 works fine.....
what's this???
can you confirm that i can run it in win7 64 bit using 8 GB ram?
i'm not interested in STS sampler or ctx mode, just be sure to be able to use SFP in standard way with sonar 8.5 in 64 bit mode with a i7 quad core! :-|
first i will buy scope, then in 2011 the new pc w/win7 64 bit
it means scope should access a max of 4GB ram in w7x64. It means that any 32 bits apps in a 64bits OS can access 4GB of ram for itself (it already makes a big difference in the number of plugs loadable, compared to XP32, for me at least). by the way, a lot of vst plugin work also in w7x64 as a 32 bits version. sometimes , the 64bit version is simply not working in the 64 bits DAW (i can't tell if this due to the dvelopper of the plugin or due to Cubase) so the daw will access all the ram, but it will be used by either 64 bits or 32bits vst plugins. It happens that some 32bits plugins cannot be loadable by a 64bits DAW, but there is an app/wrapper called Jbridge that allows to load those plugins (only for PC, this is not possible in Macs yet). I haven't needed JBridge yet (in fact, on my setup, only a Cakewalk Rapture LE (32 bits and XP version) that came with a midi keyboard is not compatible with...cubase x64 ... but i haven't tried with JBridge yet (not sure i will eventhough Rapture is very good even the LE version has nice sounds, but well...). it is more than 75% of my vst plugs in Cubase that are 32bits.bosone wrote: what's this???
Great - been waiting for this. Thanks for the heads up.XITE-1/4LIVE wrote:Modular IV Manual is available.
