Adern Announces Xor and Mojo, Two new plugins for the Scope
Planet Z Announcements
greenbluegold
Re: Adern Announces Xor and Mojo, Two new plugins for the Scope
Post by greenbluegold »
oh yeah, well I know what I did. Saved a few afterwards that come close, but that one was the best. Or maybe not, sometimes the ears just need a rest. :-) If you want to make something similar, play around with the morphing oscillators and the all pass filters.
XOR is a fantastic sounding, and incredibly versatile synth with an intuitive and original design. The way the modulation section is implemented allows for remarkable control over very complex changes using only a few parameters.
next to nothing
Post by next to nothing »
Again, its a very useful synth. Heres a quick snippet, drums are samples, only a tad of masterverb is added, everything else is preset (and the obligatory manual filtersweep).
Yeah NTN,
Now we're cookin'.
Which Drums are you using, they have a nice edgyu sound?
next to nothing
Drums are RM V, from linplug. Just started using it, but from what i have touched at the moment i quite like it.
ReD_MuZe
Post by ReD_MuZe »
next to nothing wrote:Again, its a very useful synth. Heres a quick snippet, drums are samples, only a tad of masterverb is added, everything else is preset (and the obligatory manual filtersweep).
Woha Phat gains a new meaning in this track :)
in addition to the obligatory filter sweeps, on xor one might like to try the waveform sweep ;)
grappa
Post by grappa »
Tom Sawyer takes me back Jimmy - Definately in my top 3 filter sweeps of all time :)
Xor sounds frikin awesome!
iSiStOy
Post by iSiStOy »
After some déboires with the bank transfer, ShareIt notified me it's been received today (been sent 1rst time last tuesday but refused by the bank).
Can't wait to try it in my new project now!!! Hopefully just before the week-end :wink:
Denis
ReD_MuZe
Post by ReD_MuZe »
you might like to check your email :P
Refrochia
Post by Refrochia »
Next Friday is payday!!! Its time for new toys!!!
One thing though Red - please please please release Phil and Grainmiller. How close to completion do you get with these (if you dont mind me asking)? :D
There are known knowns. These are things we know that we know. There are known unknowns. That is to say, there are things that we know we don't know. But there are also unknown unknowns. These are things we don't know we don't know.
iSiStOy
Post by iSiStOy »
Nice! :D
iSiStOy
Post by iSiStOy »
Just a question : is there any mean to tell scope that a plug needs to go one one board and not another? Some troubles with gen 1 again, I think... Thanks in advance.
Immanuel
Post by Immanuel »
Great to see, SC put your new devices on the site :)
iSiStOy
Post by iSiStOy »
K, no pbs at all! Just that it's so tasty it might need some bandwidth to excel! And it does for me.
I'd say it helps going back to the roots of some sort of sound:TB motion emulations and other searched effects on synths just true killers!
Clearly an essential for my goa projects :D
ReD_MuZe
Post by ReD_MuZe »
Refrochia wrote:Next Friday is payday!!! Its time for new toys!!!
Phil and GrainMiller may be released in the future. but its going to take some time... phil was almost finished, grainmiller needs to wait for phil to be finished...
Next friday is messe, some delays can be expected...
glad you like the synth!
ReD_MuZe
Post by ReD_MuZe »
iSiStOy wrote:Just a question : is there any mean to tell scope that a plug needs to go one one board and not another? Some troubles with gen 1 again, I think... Thanks in advance.
not that i know of in scope, in SDK it is possible for sure. Xor however shouldn't have any problems with v1 cards...
can you get into details?
iSiStOy
Post by iSiStOy »
I set 4 voices of poly, then when changing presets I get the msg below, even though my DSP meter is fine. When going back to 2 voices, preset changes are smoother.
ReD_MuZe
Post by ReD_MuZe »
and if it lands on the 15 dsp card you get no errors?
next to nothing
hmm
im away from my DAW at the moment, but i also get communication errors at times. i can look deeper into it over the weekend, but to me it seems to happen when i spread the device across my 2 cards (Luna 2 and a 6dsp XTC). Fom my part i seem to remember that it helps to first fill up my luna with mixers etc, then load Xor.
On the other hand, if i skip the mixer i can fill all my 9 dsp with xor voices without trouble. the error occurs when changing presets, but not on every preset...
I also note that when trying to reallocate DSP resources, i dont just get the single "click" sound as usual, but more a "rain" of quick clicks, like if you are jerking a bad audio cable.
I can look deeper into this when im back home.
PS. I find it strange that isistoy are experiencing this with 4 voices on 2 15-dsp cards, as 4 voices takes almost exactly 4 DSP. BUT as a coincidence, most of my trouble happened at 4 voice poly as well, on the demo i made above i used 5 voices and had no trouble....
ReD_MuZe
Post by ReD_MuZe »
i will do some tests, and when i go to messe i will consult with holger maybe there is a way to solve this :>
iSiStOy
Post by iSiStOy »
Thanks for sharing that experience.
I checked and everything is fine with 3 voices. Not tried with more than 4.
I'm not sure it is a pb with the plug itself and I can deal with it now without any other pbs, in reducing the voices (cool to keep the setup out of preset changes by the way: voices, tempo, unison, mod & pitch wheels)
The thing is that is mislead you & myself saying it's loaded in the gen 1 board: I guess not as my mainboard is a pro gen2. The second one is pro gen1 on which I load my mixer. So there is plenty of room for plugs on the main board and I guess it's the first to be filled with when launching new plugs.
So to say, I actually have these DSP charges before and after Xor is loaded (board1 : gen2 & board2 : gen1):
Edit: 3 voices
