Digital audio Soft > a new development company
digitalaudiosoft
You are wrong here.
I am involved with audio for the last 20 years and I knoow what I meant to say.
I said that the threshold does not go down enouph to make it a useable compressor although it sounds very nice.
Trying to raise the input to have the compressor work hard the input clips.
Regards,
Dimitrios
<font size=-1>[ This Message was edited by: musurgio on 2006-05-19 03:54 ]</font>
Regards,
Dimitrios
digitalaudiosoft
hi dimitrios,On 2006-05-19 03:53, musurgio wrote:
You are wrong here.
Regards,
Dimitrios
it is not a problem
you are right,if you work at -16db ,it is not enought for pumping.
I can lower the threshold easily.
I will do it for the bought version.
thanks
ev
http://www.digitalaudiosoft.com
<font size=-1>[ This Message was edited by: digitalaudiosoft on 2006-05-19 04:23 ]</font>
Well, I got it to pump fine, on a allready mastered stereo-file. Maybe I don't understand what you mean by pumping.On 2006-05-19 03:53, musurgio wrote:
You are wrong here.
Regards,
Dimitrios
In my experience you can easily make any compressor pump by increasing the rhythmic low-end.
<font size=-1>[ This Message was edited by: voidar on 2006-05-19 17:58 ]</font>
digitalaudiosoft
now,you can download it for freeOn 2006-05-12 01:48, erminardi wrote:
Cool, the "insert4XTC" is also interesting too!![]()
ps:i don't know how to put them in "devices section"
ev
<font size=-1>[ This Message was edited by: digitalaudiosoft on 2006-05-20 08:26 ]</font>
I've found that switching the master output from stereo to mono (with my presonus central station connected to my amplifier) i get phase cancellations with all the EV plugs but in particular with the SL 9000 and the sl 9000 master comp.
No other experienced that (BIG) problem?
http://www.kwild.com
digitalaudiosoft
of course ,all my plug are with phase problem and your system not.On 2006-05-20 09:36, kwild wrote:
i have made test on all my plug.look at this please and after,do and think what you want ...
pink noise generated by creamware control room on sfp 4.5.
phase off
phase on
ev
<font size=-1>[ This Message was edited by: digitalaudiosoft on 2006-05-21 02:21 ]</font>
U are right man but i got that phase cancellations with your plugs only.
Putting you s9000 mastering comp (or what tha fuck is called) in my mastering chain (psy q/optimaster/sl9000/timeworks mastercomp hard) when i swith to mono the sound becames horrible.Without your stuff no problems...so i think i can't buy your plugs for the moment...
digitalaudiosoft
it's not false kwild, and i think we've found the problem :U are right man but i got that phase cancellations with your plugs only.
it's due to our protection module we use, that we still have modified several times !!!
first all all, it's not a total cancellation and what is more strange it doesn't appear on all plateforms !!!
the protction module seems to react differently in several situations.
We made all of our tests on full non protected versions, and the problem you've found actually exists on protected modules, sometimes ...
we are going on working on this protection module, in order to propose every one something the nearest as possible to the full versions,
thanks again for this remark,
digitalaudiosoft
