What plugins are missing in Scope? What do you want more of?
tlaskows
Re: What plugins are missing in Scope? What do you want more
Post by tlaskows »
fra77x2 wrote:"You definitely need custom code."
If this is not true, how come no one has created a JP-6 filter that I asked about about a year ago uh? It's not a joke. People have been trying to emulate the SID for over 10 years, and there's nothing perfect out there yet.
-Tom
fra77x2
Post by fra77x2 »
Have you used jp8080? (jp = jupiter ) It's all digital. https://en.wikipedia.org/wiki/Roland_JP-8000
I read a post of you where you said that Novation Supernova has weak oscillators and filters
(compared to Virus and Nord). Perhaps you don't know how to use these correctly.
I have used all these synths and Novation has great sound, osc's and filters.
I have also used Virus C, TI, Nord Lead 3, Nord Modular. All have fine digital filters.
I found this replica of the jupiter 6 filter, do you like the results?
https://www.youtube.com/watch?v=iIVMCpU6kTI
I can model such a filter in the sdk, (also in the modular).
It just needs experience and know-how.
You can't imagine how much stuff can be done with straight signal processing.
About the SID, what to say? If you study the waveform you will see there is nothing special.
It uses a form of phase distortion.
tlaskows
Post by tlaskows »
Come on man,
You tried to offer me SDK lessons. And you're offering Modular lessons.
When I buy something, it always comes with a manual.
ok, now this is getting out of hand. please stop.
Tom, you are just in the wrong and you don't know what you are talking about. please do not take this any further.
fra77x2
Post by fra77x2 »
garyb wrote:ok, now this is getting out of hand. please stop.
Well, I thought we were getting somewhere. For an interesting discussion you need questions and propositions.
I've learnt to know Tom as someone who can handle a good discussion and knows to position himself in a field of discours.
Why so afraid?
With respect for your task as moderator tho :)
Tom's fine, but he doesn't really know what can or can't be done, yet he's stating opinions as fact. he doesn't have the SDK or a card or an XITE. there's no point in his arguing with fra77 or vice-versa. this thread was started by faxi because he wants to make some things that people might want. really, there should be suggestions or crickets, but we all like to get off-topic. that's also cool, but let's stop that before it gets out of hand.
i'd just like to see something positive.
personally, what i've always needed is a meterbridge that could use between 16 and 128 sources. the stock meterbridge is limited in it's assignments, though i suppose i could use multiple devices. what i hate about it is if you assign the first meter bank to a mixer and then assign the second bank to the mixer, the numbering doesn't continue from where the first bank left off, instead it meters the exact same sources, so that there are connections that never get metered. it's not a big desire or a glamorous project...
FrancisHarmany
Post by FrancisHarmany »
fra77x2 wrote::)
This is an excellent resource:
https://www.google.gr/url?sa=t&rct=j&q= ... kQt3bnsL8Q
Nice! Thank you.
fra77x2
Post by fra77x2 »
@garyb
Are you talking about this?
And you want the numbering assignable on each instance?
I can't spend a lot of time, but a rough design is possible.
tlaskows
Post by tlaskows »
Sorry, I'll be good.
Yes, I did have the SDK. No, couldn't do even a simple, actual DX7 emulation with it. So I bought the real thing.
I'm not gonna argue anymore, cause there's no point.
Back to bed :sleep:
-Tom
@ fra77- no, that's only 16 channels. check out the stock meterbridge. it's assignable, it doesn't need to be wired, but it's no good for a mixer because of the way the assignments work. otherwise, it's perfect.
@ Tom-thanks. i think it takes a little longer than a few days to say what can or cannot be done in SDK. i agree, though. if you want a DX-7, you need a DX-7. there are a lot of them and they're cheap. it also takes a DX-7 to model a DX-7 properly. memory won't do. in any case, what makes a DX-7 hard to model in SDK has nothing to do with the filters.
but enough about DX-7s. please use this thread for positive suggestions of things you'd like to see in Scope. i realize that there really are a lot of tools already, but i know there are more that would be cool. a good harmonizer/chorder/pitch shifter would be cool, especially with a recirculating delay added. i can make this in hardware and my Lexicon LXP can do some of it, but a integrated plugin would be nifty.
fra77x2
Post by fra77x2 »
Unfortunately i haven't used the stock meterbridge. Anyway i quickly made the sdk module with assignable numbering.
You have to connect it manually though.
If you don't find it useful delete it.
vu_x16.zip
(102.21 KiB) Downloaded 268 times
About the possibilities of the sdk and the "dx-7" of course the discussion is not serious.
A DFM engine is perfectly feasible, but one should design the sine oscillators from scratch
because there is no sine oscillator stock atom with phase modulation.
I have done it. Of course i made it in 2015 which means 10 years after i started using the sdk. :D
The Fm oscillators of the sdk and the modular are very good and the timbres created with FM and DFM are pretty close.
About the " a good harmonizer/chorder/pitch shifter would be cool".
My opinion is that a pitch shifter algo to work right is not an easy job.
I have created such a device but unfortunately i can't share it for free.
fra77x2
Post by fra77x2 »
:wink:
Post by JoPo »
fra77x2 wrote::)
and this:
http://www.soundonsound.com/sos/allsynthsecrets.htm
and a must-read: "the secret of the the Big Red Button"
http://www.soundonsound.com/sos/jul04/a ... ecrets.htm
Awesome ! Thanks for those useful links ! :)
nobody's hard work needs to be for free. that is children's thought. :)
fra77x2
Post by fra77x2 »
Yes, i think it is obvious.
Anyway, i read in some other post that there are not adequate envelopes "to use for the non ADSR modules of the dx-7"
this is not true:
a. There are multistage envelopes. 128 stages + repeat function.
b. One can make different contour modulators by using more than one envelopes or mix it with lfo's etc. It's modular.
c. There is a Ramp generator in the sdk, it can be used to create the different parts of a custom envelope.
d. One can make envelopes with Async modules as i have demonstrated in the past,
an unreleased version of VOID2 offered two ADSTR envelopes. T(ime) was a parameter that affected the sustain stage,
and made it gradually rise or fade with slope defined by the T parameter
But truly, the main part of an FM synthesis engine is the fm synthesis capability, be it FM or DFM,
the amount of operators, the connections i.e. "algorithms" between those. The modulators, are not really crucial.
Fm synthesis is a very powerful way of digital synthesis because it creates organic and rich timbres.
Lately i created a "nordlead3" fm synthesis engine with 4 operators, i.e. 2x2 sines an octave apart and 3 amounts of fm index. 1*2, 3*4, 1_2*3_4.
The sound is the same with the nordlead3 as i have the instrument.
I insist, working digital synthesis without an oscilloscope is a nightmare.
faxinadu
Post by faxinadu »
thanks for the ideas amigos!
our first device releases will be coming soon, stay tuned for news from myself and sonic core :)
i think some of you here are looking at this whole thing in a very strange and wrong way. who cares if you can emulate 1:1 exactly X filter? Scope is an amazing platform with its own core sound and core workflow both in the user and developer experience.
in one of our devices we have a flawed "supersaw" osc. it mimic's everything except one characteristic of the roland supersaw. is it as "good"? is it an "exact emulation"? who cares?!?!?!? its a beautiful machine for the scope family!
the question should be - does it sound cool, is it fun to use, is it making interesting use of the scope platform, does it add flavors and tones to the platform, and are you getting actual work(music) done with it?
http://www.oceanswift.net
Music
yes, Faxi!
FrancisHarmany
Keep on playing people :)
Post by jksuperstar »
Pygmy Audio Farms wrote:Faxi...
Can I get a PitchShifter which can PitchShift each partial individually to detune the signal with four mod inputs, X,Y, 2X, 2Y. All partials below X are shifted according to Y and all partials above 2X are shifted according to 2Y
Check out GOST Dynomic (part of his Harmonic Effect bundle). It will detect the fundamental of a note, then have several controls for each Harmonic. You can use a pitch shifter on any given Harmonic, as you see fit (or other effect).
http://sonic-core.net/joomla.soniccore/ ... 37&lang=us
