Successful Full Range with Silentway Voicecontrol
Re: Successful Full Range with Silentway Voicecontrol
I have a few of them, they are 1:1 accurate, and replicate every switch too.
Check the Xforum in your pm later.
Also just built an excellent MIDI Controllable w/o relying on the DAW for automations.
I can merge automation data from my hardware controller that overrides the sequencer.
This is way cool and the patch will recieve PrgmChng, CC, Aftertouch and all of the
goodies while maintaining audiorate Modulations...............Sahweet.
Below, just using snapshots and an extra MIDI Filter, I can control every aspect like
before. All that has changed is the addition of audiorate Modulations.
The patch Ben linked you to is an older version, but pretty close.
I will still send you the updated one with built in distortion, and Mod IV'd.
I will send that to you too Ben, thanks.
FWIW, Assaf Dar was responsible for the patch creation during his online
Modular classes.
Modular classes.
I tried Sylentway with Modular. fantastic accuracy.
now I'm truly happy.
XITE-1, Reaperx64...
Here's the new and improved SilentWay Suite Vrs. 2.0.
It's fantastic and no longer requires CompAX or any extra modules.
Strictly VCA, FIlters, Poly Out and Oscillators.
Here's the massive mono beast WALL OF FAT.
CFM Sweeps using LFOs and ADSRs for Sync'd Oscillators following the rate of LFOs is truly powerful and are just a pleasure having.
yaay!
- sound examples?
im 700km away from my studio right now but when I get back I´ll check it out...20$ for the upgrade? thats ok.
I'm still learning the preferences and how to get Polyphony using 4 x Modular patches, or a single one.
I need to recalibrate your txt. file though. I can just adjust the tuning, but I want it to be like it is suppose to be.
All I know is Modular is sounding so huge, and with different shapes and Portamento amounts, this can be a very powerful option.
I really only need 3 x voices but a 4th for transitional/note stealing tricks.
dawman wrote:I'm still learning the preferences and how to get Polyphony using 4 x Modular patches, or a single one.
why do you need to adjust the txt file, whats wrong with it? - compax wasnt needed in prior version from what I know, It was needed if you wanted to use the mod´s internal envelopes, if you wanted use voicecontroller´s envelopes you could just do that imho
nice patch though, how did you get adat inputs into modular or is that some kind of XTC mode?
Sustain Pedal added in SWS 2.1 due out "soon."
This is great news as now I can concentrate on this for the gig, instead of a fun experiemnt at home.
I guess having a performer in the ranks has it's benefits....nobody else in the entire forum ever mentioned this which makes me wonder what are they doing with this remarkable software...?
I think I am going to try and build a Modular Patch as a mixer using psuedo VCA groups based on audio as a modulation source.
The Wall Of FAT has returned. 4 voices, voltage controlled VCAs, EGs, LFO, and seperate Oscillator Detune and Glide.
Most of the controls are set in Silentway Suite 2.0.2 hosted in Reaper.
- 4 voice voltage controlled synth.JPG (166.25 KiB) Viewed 6909 times
I didn't mention it? I miss it badly too, after all you just cant use your feet to make music, and I like using almost all body partsdawman wrote:Sustain Pedal added in SWS 2.1 due out "soon."
dude, where went the post with that anal stuff?
check this first demo out, also I made a thread on gearslutz
http://www.gearslutz.com/board/electron ... ost8695301
Soundcloud:
https://soundcloud.com/demoguy/se1-x-mod
Soundcloud:
hi jimmy,
I dont know yet, we still neeed to finish it
- you could ask stefan directly though via his website/blog, he speaks perfect english, here's the link 4u
http://www.huebner-informationselektron ... ticle_id=6
and another demo, lets call it level 2, or level intermediate...maybe there will be some pro level demos in the future ^^ but I think Im not gonna loose too much time with the mod, as in this stage I won't be able to total recall once I get back the unit next time from stefan.
https://soundcloud.com/demoguy/se1-x-3-voice-anyone
edit: and just another demo arrived, showing off some audio rate modulation on the se1-x filters on an external signal...the external signal was stereo so I just recorded all manipulations in the sequencer, switched channel and did a second recording while altering the cv of one channel a bit, it gives quite nice stereo dynamics and is fun, check the descriptions
https://soundcloud.com/demoguy/se1-x-external
Wow that's nice.
I do not wish to progress past the preset stage since I hope I can still have preset capabilities, just for Oscillator and Filter choice recall.
I shall follow up on the links, thanks TL. Shit looks and sounds fabulous.
hi!
of course preset capabilities are still here just as before, they dont get altered by the mod, only thing: if you have a cable plugged into one of the inputs like filter cv or vca cv, the internal signal gets bypassed, but: every cv input is buffered to an output before the bypass, so you can just route a cv signal out to your converter and loop it back, which means preset functionality will remain almost 100% intact even with all cables connected!
