VM-1242 .. no longer available
Shroomz~>
Post by Shroomz~> »
Katano, yes there's a clip led at the top of the meters as usual. :wink:
Herr Voigt
Post by Herr Voigt »
Coloring the knobs of EQ, pan, send effects etc. would be great.
Placing the meters at the faders is great, too.
So it could be THE scope mixer of the future.
katano
Post by katano »
Shroomz wrote:Katano, yes there's a clip led at the top of the meters as usual. :wink:
of course, stupid me, how could I ever doubt it :D
I want wobbling meters!
use the blue pill - or some kind of mush... :P
Shroomz~>
Post by Shroomz~> »
Yeah hub, half of your local shops sell Mexican shroomz :D
A Family Outing.
kylie
Rank-o-phile
Post by kylie »
- give us the meters :)
- give us the knob colouring :)
I'm fine with the knob style.
unfortunately everything is still packed and stuffed, so I probably won't be able to test it before v0.2 anyway... :)
-greetings, markus-
kylie
Rank-o-phile
Post by kylie »
scope4live wrote:A Family Outing.
nice one :)
bill3107
Post by bill3107 »
it looks great.... let us know when it is finished ! Thnak you so much for this device !!!!
hifiboom
Post by hifiboom »
Great efforts... :)
voidar
Post by voidar »
Could you do a bypass or "unload device from DSP" kind of feature for this too? Like some sort of hybernation mode.
Say I try to load this up in XTC mode (I haven't tried yet though - I'll get back to it) and I want to save my DSP for processing individual tracks before mixdown (with your mixer), this would be pretty handy for dynamically allocating my resources to where I need them :)..
Do you think this would be possible?
Shroomz~>
Post by Shroomz~> »
I guess you missed me saying this the other day ...
Shroomz wrote:What I've done tonight is add 2 on/off dsp switches which don't require the addition of more circuitry to compensate. One switch releases the WHOLE device from dsp which could be handy. The second switch releases ALL of the aux sends & returns from dsp which frees almost 2 whole dsps without breaking the main channel signal paths. Works great!!
So it's already done :wink:
voidar
Post by voidar »
Aaaah :P... Sounds good..!
Looking forward to try this out.
voidar
Post by voidar »
BTW.
Would it be possible to add a stereo input that will operate during full bypass that just passes the audio to Mix output?
Or perhaps better, just a monitor input like the STM 2448/4896 which routes straight to mix out that won't be effected by the full bypass/power-off.
voidar
Post by voidar »
Your mixer loads up in XTC mode using the DEV->MDL-rename trick. :)
However, I am having problems phase cancelling with your mixer. The DSP management one is obviously more efficient, but its not silent.
I am running + signal into odd numbered channels and - signal into pair numbered channels from the sequencer.
None of the mixers are silent. The difference seem to be that the non-DSP managed mixer has this obvious out of phasing sound (no lows, shrill highs), while the DSP-managed mixer has this audiable crackling sound.
It kind of sounds cool. Like a radio cought between stations or something.
I guess this is meant to be due to the tube-simulated circuits? Some non-linearites must be.
Shroomz~>
Post by Shroomz~> »
v0.5 is available in the first post !!! :cool:
http://www.planetz.com/forums/viewtopic ... 30&start=0
voidar wrote:Would it be possible to add a stereo input that will operate during full bypass that just passes the audio to Mix output? Or perhaps better, just a monitor input like the STM 2448/4896 which routes straight to mix out that won't be effected by the full bypass/power-off.
I'll look into that Voidar, but I can't promise anything!
You mentioned that the mixers aren't silent & yes, that is the case. It's a product of the mixer's ECC83 tube sims. I'm looking into this issue :wink:
hifiboom
Post by hifiboom »
hey Shroomz the updated GUI looks way better than the old one...
the added contrast is visually much better on the eyes right now....
good work, man !!! :wink:
is the graphic a current one ?
...the added contrast is visually much better on the eyes right now...
it really kills me, Tom
(have to recover from nausea - it's just an observation, not meant negative at all... can you really look at it for longer than 20 seconds... ?)
Shroomz~>
Post by Shroomz~> »
Have you refreshed your browser cache Tom? If it's got the two link buttons down the bottom then it's the current one.
