CAPO SE-70 (guitar multieffect insert module) - FINAL!
erminardi
Post by erminardi »
gainman wrote: Leaving that, I have found a couple of somewhat annoying things:
* Switching on/off one of the stereo slots produces a change that can be heard first in one of the stereo channels and then in the other, which is not nice for switching on/off effects on the fly.
* When loading a project that contains this device, the configuration of the device is not loaded correctly. That is, you load the project and e.g. dynatube settings are not correct. Then you have to load the preset in capo to get the right settings.
Have you experienced this?
Uh, in my system these issue are absent...I work with Scope 4.5 and an AMD 3500+, 1GB ram, win XP sp1.
I can easily load projects with CAPO SE-70 preset without problems and the on/off switching is flawless.
I can't say more about your problem.
Let me know your system.
gainman
Post by gainman »
It's strange that it happens to rodos and to me but not to you!
Some further clarification on the problem, just in case...
* The switching issue happens e.g. if you put an stereo effect (e.g. stereo chorus) after the amp slot and then switch that stereo effect on/off. It doesn't happen to me before the amp slot.
* The project issue happens only with some of the devices loaded in capo, e.g. with dynatube. Other devices recover their settings correctly.
My system is also scope v4.5 in a rather old PC (I can't recall exactly now, but I think it's a Pentium IV 1.8 GHz with 512 MB RAM).
rodos1979
Post by rodos1979 »
Same thing with gainman here. I think it's only Dynatube, which doesn't remember settings.. But can't be sure, as I ve not checked all devices.. PEQ4 and Gate remember their settings..
P4 2.4GHz, 2GB RAM, Scope 4.0
erminardi
Post by erminardi »
Mh, sorry, same for me with Dynatube... :roll:
But I think that the problem is into Dynatube dev, so I cannot fix it :(
SDK is so "delicate and sensible"!
If everyone has an idea for fix this issue, is welcome.
