How to make an STDM cable for cheap
Re: How to make an STDM cable for cheap
Immanuel
Post by Immanuel »
Aah! I saw these pictures too. But when I looked at Neutron's picture, it appeared to me that they where single clamps used for two cables. Maybe they are individual clamps, which just sit shoulder to shoulder on the cards?
haba
Post by haba »
Hello I'm from Germany and in the need of one STDM cable. The standard cable dosn't fit my motherboards PCI slots. Does this two Items would fit my needs?
http://www.ebay.de/itm/2PCs-Card-Edge-C ... EoS9knYCyw
http://www.ebay.de/itm/20-Pin-Card-Edge ... SwKrhVds5r
Thank you for watching!
haba
S/TDM cables connect two or three cards together. they go on the card, not the PCI slot.
this one looks correct, but i'd use gold contacts, not phosphor bronze. the bronze contacts may oxidize, which will eventually make the cable fail. i think nickel would be better than bronze as well, even though nickel is also prone to oxidation.
haba
Post by haba »
Thank you Gary, I know, but my PCI slot spacing did`nt fit the standard cable (its too short). What do you think about the other one? would require some soldering but it sould not be that bad.
They say it uses gold contacts.
the other connectors simply crimp on as much ribbon cable as you like. sure, you can solder it, but that's an ugly job.
haba
Post by haba »
thanks Gary...I habe two older original cables...the one doesn't sit well...the other doesn't make a good connection...and because I need 4 cables..I thought I'll give it a try with soldering. But your right...60 solderpoints for one cable...it's ugly...
Marco
Post by Marco »
I bought 2 cards from one guy, this is the easiest way to get the cables for nothing to pay extra because they are part of the offer! :D
I know, this will not help you :o
Now I have 5 cables connected, working great with 3 x 15 dsp cards
Runs like hell!
haba
Post by haba »
I finally bought 20 connectors for 15 euro...I have 5 X 6 DSP and 1 Luna to connect...
Marco
Post by Marco »
You are a lucky man! Really.
haba
Post by haba »
:-) I know! :-)
haba
Post by haba »
This ones don't fit...
in case that sombebody wants to to buy them.
ta7
Post by ta7 »
I don't know if the question completely answered. But here is a useful link. It is only in German but i thing with a translater easy to understand
http://sonic-core.net/joomla.soniccore/ ... 56&lang=de
Selecting the English flag icon works, for both the page and the PDF - no need for a translator.
the info here and on Scoperise has part numbers and everything...
