NOAH Screen scrambled
Discuss the Creamware Noah
Re: NOAH Screen scrambled
MrV wrote: Sun Feb 04, 2024 3:44 am ...the drivers were still not installed ( ?? ) and I assumed they were because I was controlling the synths from the editor..
Anyway now they are ... I updated the Noah and Wave drivers via Device Manager.
O.k.,- congrats to the driver installation !
MrV wrote: Sun Feb 04, 2024 3:44 am I need to study the manual obviously because I've never used this thing.
I was in the same situation and figuered the most out myself,- which was the reason my reports, when read one after the other, appear like a nitemare.
Reading the manual chapters is essential like it is w/ every other MIDI module multitimbral synth !
What do you mean by "bi-directional" ?
There´s several:
MIDI:
Can be used bi-directional and in any combo of USB-MIDI and physical MIDI.
Noah is a full featured MIDI interface
Audio:
Noah has Audio-Inputs which can be routed in several ways and there´s the usage of ASIO and WAVE drivers.
In fact, Noah is still a full featured audio interface,- although, not on par w/ today´s USB2 audio systems.
And when you own some CPU friendly and good sounding aged WinXP SP3 compatible 32Bit plugins,- you have the option running ´em off the machine the editor runs on and via ASIO thru Noah´s audio outputs.
Both of the above and how good that works rely on propper driver installation and optimized Windows (XP SP2/ SP3).
MrV wrote: Sun Feb 04, 2024 3:44 am I can't see any From Noah or To Noah tabs in the Synchroniser ??
Sorry for typing from my head when I´m at my office machine ... it´s not in the "Synchronizer
You find on page 7, Noah Remote Editor manual,- "The Control Bar".
The leftmost tab in the editor´s Control Bar allows switching data flow direction "From-" and "To Noah".
In the "Synchronizer", bi-directional is all about uploading or downloading presets to/from Noah.
It´s all explained in the manual.
A quote here:
"The Noah Remote Software does not store its presets directly in the Noah hardware.
Instead, it stores them on your computer's hard drive – or, to be more precise, it stores them as files with
the extension .NPL in the appropriate subfolder of the folder \Noah\Noah\IF.
Thus, the set of presets stored in the hardware may come to be different from the one stored in the software.
With the Synchronizer, however, you can conveniently compare the two sets of presets and eliminate the differences
between them."
In Synchronizer there are additional tabs for IF (internal flash) and CF (compact flash) in addition.
So,- it differenitates between Noah (IF), the Editor (HDD) and Noah CF-Card slot/media.
For standalone operation, the CF card slot is usefull to backup your presets and edits you do using the frontpanel alone.
You DON´T need a computer being urgently connected !
MrV wrote: Sun Feb 04, 2024 3:44 am Also , in the registry there is only the Hardware SN there are no keys displayed. Hmmm that's not good . But the synths are working fine in the Noah and outputting sound . So how is that possible ?
Ooops ! No idea.
I hope you didn´t wipe the keys accidently.
MrV wrote: Sun Feb 04, 2024 3:44 am Maybe because Noah is v1 but the new software is v1.1 ?.
There´s the Remote Editor software versions,- v.1.0 and 1.1.
The latter is update from 1.0,- but that´s NOT the NOAH firmware/system software.
When I got my NOAH EX w/o keys because the owner didn´t find, the machine worked too and it looked like this,-
system software version is displayed ...
What does your´s read now ?
Noah EX system version.jpg (80.1 KiB) Viewed 39321 times
But it wasn´t perfect.
So, I gently asked S|C for new keys for my Noah EX hardware serial number, reflashed the toy and installed all new from ground up.
Since then, everything works perfect and there´s Noah´s latest system software loaded.
The one and only device not working perfect is "Prophet 5",- unfortunately.
I still cannot thank Gary and S|C enough for all the help, hosting software and providing new keys for a since a long time discontinued "Creamware times" product !
When I´m upstairs and have the time, I´l power up my NoahEX, make a pic of the displayed latest system software number and upload here.
MrV
Post by MrV »
Thanks Budweiser.
Yes the From and To are in the Control Bar next to the Single / Multi box .
There are no more yellow warnings in the XP device manager , so all drivers are in now .
The usb "light" is on in the editor but not on the Noah (.? )
Pretty sure I haven't wiped any device keys but it's weird how they are not showing in the registry. Seller sent me all the keys anyway in case I need them ...but all the devices load correctly in editor , 4 separate synths across 4 mixer channels in multi mode etc .
I notice they mention USB Audio....but this is only USBv1 right ?
pretty low bandwidth I would have thought ....
Here's a pic of showing the Noah firmware version
Cheers , Michael
MrV wrote: Sun Feb 04, 2024 6:01 am ...
USB 1.1
MrV wrote: Sun Feb 04, 2024 6:01 am pretty low bandwidth I would have thought ...
yeah, but when you need just only 2 channels of audio out, it should work 44.1K / 16Bit and w/ 256 samples buffer size.
The "old" Sonic Projects OP-X is very humble on CPU and a good addition since there´s no "oberheimish" device for Noah (and SCOPE).
On more advanced DAWs, I used OP-X Pro, Pro - II and nowadays the latest OP-X Pro-3,- but the 1st version sounded good already.
Layer w/ some Noah synth for pads and it sounds great.
MrV wrote: Sun Feb 04, 2024 6:01 am Here's a pic of showing the Noah firmware version
that´s the latest which I have too.
Noah´s USB-LED should be lit only when there´s the USB connection between host computer and Noah.
It doesn´t indicate MIDI ...
Might be dead,- or any other defect.
MrV
Post by MrV »
Ah ok , thnx Bud :)
I'll check out the USB Audio option.
So the empty registry box is fine anyway or should all device keys be showing?
Cheers , Michael
MrV wrote: Sun Feb 04, 2024 2:12 pm
I´ll power up my rig when I´m back home and doublecheck before typing something misleading from my head here.
What do you have installed up to now ?
In my keyfile I have keys for:
# Noah Editor
# Synthesizer Package 2
# Minimax
# Six-String
# proTone
# B-2003
# Vocodizer
# Interpole
# Prodyssey
# Pro-12/Profit 5
MrV
Post by MrV »
Hi Bud ,
Noah has keys for
EDS8i
Prodyssey
Interpole
Minimax
Protone
Synthesizer Extension
Vocodiser
Sux String
In my Editor Live Bar
I can see and load
Lightwave
B-2003
Vectron
Pro One
Mixer
MIDI Manager
Aux FX
StepSEQ
Arpeggiator
Module Registry shows Installed Hardware as Noah ( with its key )
But the devices box is completely empty, no devices showing.
Not sure I understand what's going on with this because it all seems to be working fine .... ??
I bought an old Toshiba XP SP3 laptop to run the Editor and currently using that .
By the way.
My main Scope system has 3x Scope Pro cards in an i7 Win 10 system . Could I put a virtual XP system in that instead and run the Editor that way ?
Michael
a virtual machine may work, but it will not work 100%.
MrV
Post by MrV »
Ok thnx Gary .
Well the old XP laptop seems to.be working fine , except for the missing registry keys ...not sure what bearing that's having ,if any.
Sorry for being late,-
my Noah´s registry shows the Noah hardware serial number as well as all the keys !
I wonder what your "Synthesizer Extension" key is.
So, my keys (see above) look a bit different than yours, but I installed everything available for Noah and use Vectron (not only the player), EDSi and Lightwave too.
I guess these are covered by the "synthesizer package 2" key in my list above.
I also didn´t run into memory issues when I installed everything available incl. all the preset banks.
There´s still some memory left over.
I remember I had such case and lost a preset bank, but removing and re-installing a device w/ it´s banks solved the issue.
Surprisingly, the USB LED doesn´t do anything on my Noah too,- at least not, when I set the live bar setting to "to Noah", open a synth´s GUI in editor and move a control,- p. ex. master volume or OSC volume, filter cutoff or such.
I tried w/ Prophet 5 which urgently needs the editor application for synth parameter edits.
I didn´t pay attention to the USB LED before,- also because everything works.
I´ll investigate when it will indicate something and report back.
MrV
Post by MrV »
Thanks for that info Bud ,much appreciated.
Michael
