Roland Zenology 2
Re: Roland Zenology 2
If you search the forums, you'll find old posts with broken links under "Jaded800". I made sure when that modular patch was made that the WAVS were extracted to a separate zipfile, and archived all related files. Here they are attached. Caution, if memory serves the sample pool has issues in modular, but the individual waves may still interest you. If memory serves, this was made by sampling the JD800 with filter and envelope completely open and then selecting a looped or single cycle and creating a sample out of that.
JD800Wavs.zip
Individual Extracted WAV files
(1.85 MiB) Downloaded 494 times
JD800 Internal Waveforms Standalone Pool.zip
Standalone Modular Sample Pool
(1.87 MiB) Downloaded 478 times
JD800 Internal Waveforms Pool.zip
Jaded800 Sample pool
(1.86 MiB) Downloaded 455 times
Jaded800.zip
Jaded800 MDL device
(2.74 MiB) Downloaded 484 times
Thx a lot,- good to have these back !
I had these somewhere on an old HDD,- but then, drive crashed and I didn´t find a way to recover the drive.
Lot´s of SCOPE stuff possibly lost forever on my side ...
What was the difference between "Internal Waveforms Pool" and "Internal Waveforms Standalone Pool",- except one is .mdl and the other .dev ?
Is using .dev an alternative vs usin ."buggy" .mdl ?
Or do have BOTH issues in Modular ?
I wonder if these WAV files would be usable in Vaporizer 2
https://www.vast-dynamics.com/?q=products
https://www.vast-dynamics.com/?q=Vaporizer2
Not exactly the architecture of a JD800,- but at least, there are 4 Wave-OSCs,- and it´s freeware.
mdl can be loaded into modular, dev can be loaded right into the Scope window (mdl can too, but dev is the more correct packing for devices in the routing window and/or the sidebar).
In theory packed waveforms can be used in Vector, but it's been so long since I did that I can't recall if it was the Speilraum version that enables that or the stock device itself.
Nestor
Post by Nestor »
:) I don't need it myself, but I want to thank you Valis for your kindness posting it here, cheers
Posting it largely because it's referenced and I know it's among the broken links. I have such a massive archive of things I'll never have the time to touch...
