With or Without Windows Defender?
Nestor
Re: With or Without Windows Defender?
Post by Nestor »
Now it is time to go through aaaaalllllllll the installation process, so patience.
I did flash both bios. There are two switches you have to move in order to install in one first, then you turn your system off, then you change the positions of the switches, then you apply the install to the second bios. I did it twice because I wanted to make sure I killed the virus entirely, so I installed first a bios from 2015, and then the latest one again, problem solved in that respect.
I confirm that Windows10Debloater is FANTASTIC! I recommend it entirely, it is extremely efficient and easy to apply. In just about two minutes, you get read of all Win 10 crap. It is so easy an perfect that you can apply it every time you upgrade your system, as I say, two minutes and you're done.
I don't think I need any other measure against Microsoft, that is, with this, I imagine and hope it is enough, otherwise, I will apply what Bud recommended me. Cheers.
