Just a couple of minor things i found with the newest devices. Xite-1 Scope 7 Windows 7 64bit
Scope Commander:
Commander A (didn't try B C or D yet, not sure if i will ever get there as it can get really crazy with just a few!)
Slot 02
Source
Knob/Button - I think this is wired reverse?
Debbie Droner
Oscillator 2
Wave selection switch
When "IN" is selected it outputs white noise
Bug Reports
Moderators: valis, faxinadu, FernandoHood
Re: Bug Reports
on it, gimme a bit, will be fixed
http://www.oceanswift.net
Music
Music
Re: Bug Reports
It can wait
I know what you're working on
- Mr Arkadin
Re: Bug Reports
I'm on XITE-1 and thought I'd try the Enveloper Supreme Xite.dev. However I get the usual DSP error when I try to load it. I don't get this error with the non-XITE version. I realise this is a freebie so may not be top priority.
Re: Bug Reports
i know why that happens :/ ..... the xite version of the enveloper supreme locks the internal sequencer to xite's physical dsp2 as to the only current workaround to get that to work on xite. so you probably loaded it on a project where dsp2 is already doing things. if you load it on an empty or light project you won't get the error. unfortunatley, at the moment it is the best workaround we can do. i will no longer use any of those buggy core sdk modules in the future at least until the core problem is fixed on sc side... ehehehe enough is enough, only trouble from theseMr Arkadin wrote: Mon Jan 01, 2018 11:30 am I'm on XITE-1 and thought I'd try the Enveloper Supreme Xite.dev. However I get the usual DSP error when I try to load it. I don't get this error with the non-XITE version. I realise this is a freebie so may not be top priority.
Music
Music
Re: Bug Reports
just waiting on holger to make and upload the setups and then.....
Music
Music
Re: Bug Reports
Bit of a pain. But at least they can work on Xite.faxinadu wrote: Tue Jan 02, 2018 4:47 ami know why that happens :/ ..... the xite version of the enveloper supreme locks the internal sequencer to xite's physical dsp2 as to the only current workaround to get that to work on xite. so you probably loaded it on a project where dsp2 is already doing things. if you load it on an empty or light project you won't get the error. unfortunatley, at the moment it is the best workaround we can do. i will no longer use any of those buggy core sdk modules in the future at least until the core problem is fixed on sc side... ehehehe enough is enough, only trouble from theseMr Arkadin wrote: Mon Jan 01, 2018 11:30 am I'm on XITE-1 and thought I'd try the Enveloper Supreme Xite.dev. However I get the usual DSP error when I try to load it. I don't get this error with the non-XITE version. I realise this is a freebie so may not be top priority.![]()
Re: Bug Reports
SC-Server-Setup: setup_-_ocean_swift_-_scope_commander_-_xite.exe (5647 KB, 12/22/2017, 13:30:17)
Scope System (Xite/Pci, number and models of boards): xite-1
Operating System: winXP SP3, scope 5.1
32/64 Bit: 32bit
Home: https://oceanswift.net/scopecommander/
Bug Description:
>Device: Scope Cadet
- Knob rotate Value-Display with Midi-offset: Up [-1] Down [+1]
+ Text-Input without offset, is OK
>Device: Scope Cadet LFO
- only half wave then break with value 0 for negative curve
? wishlist-controller:
~ threshold level for complette "waves cycle" min<>max
~ offset for "phase"
~ CC assignment sync tempo
all the best
cheers
ron
32/64 Bit: 32bit
Bug Description:
>Device: Scope Cadet
all the best
cheers
ron
Re: Bug Reports
thanks mate, gonna look into it
Music
Music
Re: Bug Reports
OSS meets j9k
check (F)req-(O)ffset-(A)mp-(M)od/Midi, a 3x CC LFOer
the perfect toy
but without manage retrig, bpm, preset
please merge both dev`s
...than i will love you
add to wishlist:
up to 16 LFO parts in one dev (for example: to modulate CWM seq-step-knobs)
2018_12_05 > now check this:
http://forums.scopeusers.com/viewtopic. ... 70#p337755
the perfect toy
add to wishlist:
- j9k_FOAM.zip
- (124.84 KiB) Downloaded 500 times
Re: Bug Reports
Foam is a ingenious device.
j9k made so many devices different from others, making Scope so diverse.
