I was looking around for the SID, but...
tlaskows
Re: I was looking around for the SID, but...
Post by tlaskows »
Well, yes I know...
But I used to have a Jupiter 6 and there's no filter in Scope that sounds like it. Long story.
Do you just want a SAW going thru it? Because it has a bunch of different modes...
Cheers,
-Tom
fra77x2
Post by fra77x2 »
whatever you prefer. Give me something that you think it's difficult to emulate.
It's the jupiter 6 filter?
tlaskows
Post by tlaskows »
Well, the ring modulation might be a bit tricky to make it sound exactly the same. You have to do some research on how the SID was designed.
The filter will not sound the same without custom code.
The Jupiter-6 I sold a long time ago. This box only has the SID in it which happens to have an analog filter on the chip.
Cheers,
-Tom
fra77x2
Post by fra77x2 »
i haven't used ring modulation.
Ok send me a sample of this analog filter. I use straight signal processing.
tlaskows
Post by tlaskows »
Yeah, I will a bit later. I had to find my old Uno USB MIDI interface so I can play the SID while adjusting parameters.
-Tom
tlaskows
Post by tlaskows »
Boys,
1st revision of the plate. It didn't print quite right. My buddy has a let just say an old expensive industrial printer. I will see how she fits and maybe he will do quick adjustments. I designed most of it, he moved some stuff around for me.
Cheers,
-Tom
