Mod IV Delay files missing
Roland Kuit
Re: Mod IV Delay files missing
Post by Roland Kuit »
The last this with the Device search did the trick!
Thank you all! :)
http://www.rolandkuit.com/
My 7 zip app is wierd.
After un zipping twice I saw the 4 x seperate sys. files and yes they work here.
But I think I found the original problem
With the sys. files from the original app. there was also a new driver to install.
Thoses who didn't install that new driver might have run into trouble.
But your sys. files fixed that too, so now I have 2 methods that work.
Cheers
Dati
Post by Dati »
Hi guys,
I also have a problem with the Tape Delay Modules.
First it was the missing dsp/sys files, than i downloaded the new sys files and replaced the old ones.
Result was scope crashing and taking my whole system down when a Tape Delay module was opened.
I than removed the M4Tapedalay sys files, and reinstalled Modular 4, now the modules can be loaded, but a strange artificial sound is introduced with them.......
I run Scope in Administration mode, and have the search options set right.
What could cause the problem?
Dati.
Before I went to x64 the files were fine, but then I went to x64 and needed the package below that was sent to me.
There's a new driver that has to be installed, as well as the sys. and mdl's.
It can't hurt to try this, even though it is old.
This is how I currently use them and yes they are finnicky, but once set up right, I absolutely suggest using a pair of them, even 2 x short and 2 x regular Tape Delays in serial fashion.
Good Luck, and let us know if this works.
jimmy V tapeDelay.zip
(406.6 KiB) Downloaded 421 times
Liquid EDGE
Post by Liquid EDGE »
53E7 wrote: Tue Jul 16, 2013 2:48 pm Roland,
I am using 32bit Scope 5.1 as well. I never tried tape delay in Modular IV until today. When I tried it I experienced the same problem you have been having. I easily resolved the problem by downloading dawnman's files and installing them. Place the files tapeDelay.sys and tapeDelayShort.sys in the following path:
Scope PCI or XITE/App/Sys
Core, old thread.
Same problem here. I downloaded the zip file. It works, but only have tapedelay working. as it contains only 3 .sys and the tapedelayshort.sys is missing.
Does anyone please have the tapedelayshort.sys file as the other link in this thread that would probably have it doesn’t work. (32bit)
