ExpressCard arrived :-)
Re: ExpressCard arrived :-)
				lagoausente
Ok, I suspected that, but in relation with the pci bandwith? does it use the onboard memory?siriusbliss wrote:The STS still hasn't been updated (for Scope 5 OR Xite), so it still has the 1 Gig 'ceiling' (AFAIK).lagoausente wrote:The same is aplied to the STS samplers? Or don´t you know?stardust wrote:According to Ralf from SC the reason is that any reverb is using Xite's onboard memory and not anymore the system RAM.
That explains to me why the PCI(e) load is not the bottleneck anymore and makes MV test obsolete.
XITE reaches a limit by excessive use of internal connections between the DSPs.
Try 96kHzsamplerate and load QWave and a STW reverb to see what I mean.
So clever handling of DSP assignment is required and possible.
Any of you that own the Xite, can load in STS more than 700mb of samples in total?
There's a whole other thread re: the STS.
- siriusbliss
I don't know, but I doubt it.lagoausente wrote:Ok, I suspected that, but in relation with the pci bandwith? does it use the onboard memory?siriusbliss wrote:
Well, the expresscard has just arrived direct from Sonic Core, so thanks to Holger for sorting that out so fast for me. Anyway was just about to install scope 5 for XITE-1 on my laptop and then remembered that I only have Windows 7 64bit on there....DOH!!
Thought it was worth a try all the same but no go and it wont run in compatibility mode either so now am in the process of installing Win 7 x86 on another partition, and with any luck will be able to check out XITE-1 in a short while.
Hopefully they will release 64bit soon though
Will let you know how I get on later
- doktorfuture
The dsp systems use memory that is attached to them, and no main system ram.
This ram is often dedicated to each chip, which means that there is a max addressable amount of ram.
This ram us used to hold the algorihms as well as buffers for things like delays, reverbs, and samples. All this stays on the dsp subsystem and doesn't use your pci bus.
There will be dsp io processes to handle routing audio to the CPU via the computers bus. Also there will be some disk io bridge functions that communicate with the scope software to access the disk.
				lagoausente
That´s cool, that means full expresscard and pcie bandwith for multichannel Asio.. isn´t, that at least, will be lots of channels.doktorfuture wrote:The dsp systems use memory that is attached to them, and no main system ram.
- siriusbliss
Yes, at least 64-channels of ASIO.lagoausente wrote:That´s cool, that means full expresscard and pcie bandwith for multichannel Asio.. isn´t, that at least, will be lots of channels.doktorfuture wrote:The dsp systems use memory that is attached to them, and no main system ram.
Just as a point of comparison, what's the maximum with the PCI cards (on a good motherboard etc)?
						- siriusbliss
I'm getting 64ASIO with Samplitude on my PCI system.capacitor wrote:Just as a point of comparison, what's the maximum with the PCI cards (on a good motherboard etc)?
