Does scope need a wiki?
Re: Does scope need a wiki?
Checking...I'm currently using overrides for the existing stylesheet instead of doing my own. I'll try to get it usable but will probably be a comprimise (either too wide on others or too narrow on IE) until I fork things to a scopedia specific stylesheet where I can call individual browser stylesheets (instead of using some of the w/e/ll kn;own ha/c/ks for IE).
(edit)
Fixed for now (IE now has a bit of padding, FF has none for the left side)
Uploads & thumbnail generation do seem to work, as there is a Solaris image in the images folder with thumbnails. I'm guessing it broke at the point of adding it to the wiki? I may need to add more to the configuration script, there are hundreds (thousands?) of variables u can customize and atm I've only got a few dozen defined.
I'm also noticing the pages are generating a bit slowly now, have to look into that.
Viewing your images should work now, unfortunately I can't disable execution of php in the images dir and have things still function so I'm going to have to use apache to configure that area (allowing execution of code in an uploads area concerns me.)
netguyjoel
Post by netguyjoel »
logo? :wink: I know it's small potatoes on the grand scheme of things... :)
Joel
Used yours for the time being...
netguyjoel
That was just a simple rough draft...give me a day...I'll produce something better.... :wink:
All in all...it doesn't look to shabby, now that I've given it several looks now...imho
Joel
Ben Walker
Post by Ben Walker »
Alignment in IE and FF all seems fine now.
Here's a page I made earlier. Looking forward to working on this with everyone.
Ben
Looks good Ben :wink:
netguyjoel
Nice work...very cool...
Ben Walker wrote:Alignment in IE and FF all seems fine now.
Ben
Joel
I'm creating a new thread here for the wiki so we don't have to bug sherlock to edit the main post in this thread as things change...
