SPINNER (4-mode filter pan mod FX) - UPDATED 31/03/09
Re: SPINNER (4-mode filter pan mod FX) - Final update 29/03/09
Spread control works. I just made it a bit more subtle, so that you can't spread the frequencies as far apart.
Updated on 31/03/09
- Presets now load with device.
- Added WET/DRY mix.
- Altered max resonance.
- Updated GUI.
Please download SPINNER again if you already did. It'll be worth it.
~Mark
- Updated GUI.
~Mark
Re: SPINNER (4-mode filter pan mod FX) - UPDATED 31/03/09
Awesome, Shroomz! This one really sounds great, even at MaxQ, and having the Dry/Wet built-in gives a much cleaner sound than the insert (no phase issues, I guess).
And it looks even better!
Once again, many thanks!
T
Gods Of Olympus Rejoice..........
This is the FATTEST, PRETTIEST BASTARD for my ARP Strings.
I have exactly the sound of old and new combined to get gorgeous results.
I am using high amounts of Wet because the tone is just supreme, the clean channels mixed in and blended in an AUX Rack and then another Scottish device from Sharc.
QWave is going to love this on it's 4 Pairs of Waldorf Oscillators. Serious Spinnage here.
- the19thbear
one last thing!! a movement "smoothener" for the freq pot would be great!
there are alot of cool scope things, but whenever you assign a midi controller to a pot and "play it", you get unsmooth values.. or for instance chopped up filter movement.. this happens on many scope devices.
It would be great if you do something about this
thanks again
thanks again
Have you tried Medhi's CC devices?
The lag time automates movements.
I press down the expression pedal and it really smoothes things out with a high lag time.
looks awesome!!
if i only had the time to try it... soon...
thanks shroomz
thanks shroomz
Control smoothing of parameters being midi controlled comes at a price. It introduces either inaccuracies in the min & max parameter values or lag or both depending on the smoothing method. For those reasons, I won't add any smoothing. I might consider making a special nrpn controlled version, which would have a much higher control resolution, but I won't promise it.the19thbear wrote:one last thing!! a movement "smoothener" for the freq pot would be great!
I suggest you try SpaceF's midi control devices like JimmyV mentioned.
~Mark
Here's a Feisty Bastard.
I love to play on top of the Groove and have subdivisions like dotted and triplets.
Panning Filters & Panning Delays are sweet.
This one's getting deeper by the day.
Nice job Shroomz.............Ilike the way it went from a 2U to a 4U rack too.....
Jimmy
That Doors thing you did there put a huge smile om my face
Glad you like it.
I try not to repeat snippetts and I'm running out of ideas.
I was going to do Pinball Wizard from the Who, as the intro suggested, but then I had an LSD flashback and the next thing I know I was doing Ray Manzarek.
Cheers.
Cheers.
- the19thbear
Is the new version with delay ready for download??
looks amazing!
looks amazing!
