Well....I have already had to have a talk with the plugiator people on behalf of 2 of the plugins........
there is 1 prodyssey glitch with the envelope skipping 2 notes out of 10 if the decay rate and release rate is close or equal to the time a repeated note is  played.....
there is a PRO 12 glitch where if you switch between 2 polyphonic patches....the second patch wont engage full polyphony until after several chord strikes....(almost as if monophonic , duophonic or Unison without layering)The liklyhood that this happens is around 50 % it screws up and plays mono, or 50% it allows full chording from the start...
Also....regarding the whole unit, It would be nice if it had midi filters you could enable so it didnt freeze or act up when it receives midi clock at the input...
I have to disable MIDI Clock Internal on my Radias as a controller if the plugiator is after it in the midi chain...this means , regardless of channel, none of the radias sequence features can coexist with a Plugiator around...
And finally, it would have been nice if Plugiator used The out of range PolyAT channels for the overflow of CC#..... there are 21 empty PolyAT channels below an 88 note keyboard range, and 18 empty PolyAT channels they could have used above high C on an 88 note kybd....So where did they choose??? Smack in the middle of a typical 5 octave range keyboard, which means, polyphonic Aftertouch controllers wont work properly with the plugiator as key pressure on the overflow parameters will change all the parameters and knobs to 0 on release..
andyr1960 wrote:slammah2012 wrote:
How do you find the Pro 12 ???...
It sounds a little noisy compared to the prody and max...
Drums and bass has gotta go... need a new plug....
wishfully...a CS80,  Obx , mellotron or a paraphonic synth
Definitely a bit of aliasing going on with the Pro-12. I didn't bother with Drums & Bass or Fmagia - not interested in either.
I've written to Ray @ UA, and suggested something along the lines of Modular III as a plug (Clavia have stopped production of the G2 series modulars and I think a modular plug would do very well)
Yeah, a CS80, Jupiter 8, ARP Quadra would be nice
Time has No Master.
*NOW*  is the Password.
Just *ASK* and *INVITE* every-
thing you are after..........
