wolf audio design - release of 16 Channel Mixer
Planet Z Announcements
Kymeia
Post by Kymeia »
Wow - this is worth it for the modular insert feature alone. I take it this means you can load a full Modular synth patch complete with presets and play (or effect in an effects slot)? You don't have to rebuild it in the shell do you like with the other attempts at this concept?
wolf
Post by wolf »
musurgio wrote:So this could identify the actual latency of each plugin on after the other an report actual latency ?
well .. all this were just theoretical thoughts. The realisation is another thing and might be impossible.
Kymeia wrote:I take it this means you can load a full Modular synth patch complete with presets and play (or effect in an effects slot)?
Only play, not load ...
Unfortunately you need to do this with the current incarnation.
I have a solution in mind, but it needs complicated user interaction in the explorer/finder.
Beside I don't know if it works I want to avoid such kind of interactions because the user is the main problem (own experience!) when using a computer :)
dehuszar
Post by dehuszar »
I too would love a 32 channel version. That said, another approach would be to see if there's a way to load 2 16 channel devices and have their AUX busses route to both devices. Perhaps you can create a unifier device so that you can stack multiple devices and have them output to one stereo pair (or some form of merged outputs from the control room section) with their AUX's usable on all channels across devices.
The reason why I think that might be a better solution (if possible) is that we're limited to 16 channels per midi device/module, so just adding more channels would limit the amount of assignable controls. I don't know if the SDK allows you to create single devices which can be controlled by multiple midi modules (not just an multi-device omni option, a little bit of specificity might be nice), but knowing that might better illustrate our options.
But that would satisfy everyone's wishes.... more channels, more aux's, fewer licenses to purchase and manage. Good times for all.
My $.02
Here's a 32 channel hardware sequencer that Wolf's 32 would work with.
dehuszar wrote:The reason why I think that might be a better solution (if possible) is that we're limited to 16 channels per midi device/module, so just adding more channels would limit the amount of assignable controls. I don't know if the SDK allows you to create single devices which can be controlled by multiple midi modules (not just an multi-device omni option, a little bit of specificity might be nice), but knowing that might better illustrate our options.
i don't think this is an issue with mackie control protocol.....
corrections?
wolf
Post by wolf »
garyb wrote:corrections?
nope, just additions :)
Beside other advantages the MC protocol simply assures an easy setup.
But even without you can still utilize bank switches (to ie. control 32 volume sliders with 8 hardware sliders) and use any controler with any midi channel (results in far over 2064 different controlers, which should be sufficient).
dehuszar wrote:That said, another approach would be to see if there's a way to load 2 16 channel devices and have their AUX busses route to both devices.
This still would need a basic redesign of the mixer, as you want to control the aux send of each channel, not of the already mixed aux busses.
Shure, it does .. I'm just trying to imagine step sequencing a mixer :)
Shroomz~>
Post by Shroomz~> »
Step sequencing a mixer? Now you're talkin' !!!
Shroomz~>
Post by Shroomz~> »
erm... but that's a lot of shift registers Wolf :D
wolf
Post by wolf »
There's now v1.1 available with a few bugfixes and separate aux/bus outputs to i.e. route them back into the mixer.
The 32ChannelMixer might be available next week.
And here a little and completely non-pro video about the mixer in action:
low quality
higher quality
krizrox
Post by krizrox »
Yeah I have to say I would add my voice to the chorus for a new 48 channel mixer. I'm just amazed to see anything along these lines after so many stagnant years of compressors and synths that I don't need.
Those colors though... :P
wolf
Post by wolf »
48 channels ? you guys are killing me ..
What's wrong with the colors ? 8)
krizrox
Post by krizrox »
Well, the reason I mention 48 is in reference to CW's 48 channel mixer which I've been using for a couple of years now. There's nothing wrong with it per se other than a few annoyances that will probably never be fixed. I'm just stoked to see someone actually tackle something new - I don't care how many channels it eventually ends up with. I say thanks to you for that.
Come on - the colors? You got every color of the rainbow in your promo shot. It made my eyeballs freak out :lol:
Actually Brotha' Man Wolf,
I need 128 channels, how quick could you get that one up and running for me? :roll: :lol:
wolf
Post by wolf »
So the promo shot did its job .. good to know .. and I just wanted it to be prepared for the next 70ies revival :D
Actually Brotha' Man Wolf, I need 128 channels ..
Right in the moment this message is send, I'll dissolve into nothing with a silent "pfft" .. maybe I'll return as Marvin somewhen.
Great video Wolf,
I love seeing Scope with good old gear like the PC era Logic hardware surface.
You just had to show the motorised faders didn't 'cha?
