as far as I understood the procedure, the wipeout process generates a new identity for your card, which the content of the keyfile won't match anymore (it would have been too easy, otherwise).phobik wrote:What stops one from installing the pluggins afterwards with the original key file?
once the tools SC sends you have collected the necessary data and erased/changed the identity of the card, new keyfiles will be generated. the card the plugins where transferred off is not usable unless your keyfile has arrived (well, the instruction document says that you cannot use the pulsar software then. I don't know if the card would still be usable as dsp booster without the keys).
-greetings, markus-
ps. all ya hackers, be aware that simply using your scope card indoors (to avoid being targetted via gps) is NOT safe unless you disrupt a possibly running internet connection, since a stealth builtin module will sent your current google maps location to SC to provide the necessary data for the missiles
