SCOPE 5.1
Planet Z Announcements
spacef
Re: SCOPE 5.1
Post by spacef »
(14)
sounds good :-)
completely missed this thread :-)
so now we can have as much ram as W7 can take ? yes ?
plug-ins for scope
SpaceF website
SC website
siriusbliss
Re: SCOPE 5.1
Post by siriusbliss »
spacef wrote:(14)
sounds good :-)
Driver only for now.
They are still transferring the code.
Not sure why since Scope doesn't really need tons of system RAM :)
David
Re: SCOPE 5.1
Post by David »
siriusbliss wrote:Not sure why since Scope doesn't really need tons of system RAM :)
Not yet it doesn't :o
But soon
Maybe plans in the pipelines :D
t_tangent
Re: SCOPE 5.1
Post by t_tangent »
Great news. Will have to drop SC a line to get on the list :)
hollo321
Re: SCOPE 5.1
Post by hollo321 »
great news about 64 bit on the horizon, to get prepared what 64bit os u guys think is best/most stable for new scope?
xp64,vista,windows7 ?
katano
Re: SCOPE 5.1
Post by katano »
hollo321 wrote:great news about 64 bit on the horizon, to get prepared what 64bit os u guys think is best/most stable for new scope?
Windows 7 64bit is the obvious joice.
Re: SCOPE 5.1
I am using 64bit Windows 7 and it works perfectly well.
MSI X58A-GD65 / i7 930 OC'd to sweet spot.
Bidule, Reaper and Kontakt 4.1 64bit apps working nicely with Scope 5.1.
hollo321
Re: SCOPE 5.1
Post by hollo321 »
cool thnks win7 it is, cant wait to finally take advantage of all this xtra ram :D
soylent.green
Re: SCOPE 5.1
Post by soylent.green »
Started Thread for Issues with 64Bit Beta. Probably You can add your findings there
http://forums.planetz.com/viewtopic.php?f=1&t=29436
microraver
Re: SCOPE 5.1
Post by microraver »
hollo321 wrote:cool thnks win7 it is, cant wait to finally take advantage of all this xtra ram :D
???? I'm using here Win7 Ultimate 32bit with 6 GB ram !!
win 7 6gb.JPG (121.37 KiB) Viewed 5287 times
Cubase 5,Scope v5.1 XTC,2xScope Project+2x A16 Ultra+PoCo 6000(CL1B+Virus)+UAD2-QUAD(Comp,Rev,EQ)+plugiator Full.Mackie Control+Ext.ASUS P5WDH,CPU Q6600@3GHZ,6GB RAM,2xPCIe Graphics,4 Display's.Win 7 32 & 64bit.
http://soundcloud.com/dominium
babaorum
Re: SCOPE 5.1
Post by babaorum »
windows 7 32bits is like XP 32 or Vista 32 ,max RAM available for these OS is 3 Go (even if you have more RAM)
To have no this limit and use >3Go, you have to use windows 7 64bits.
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
spacef
Re: SCOPE 5.1
Post by spacef »
3.25 normal users
3.5 (approx) for hardcore tuners ... unusual amount, eventhough my previous setup showed just a bit more than 3.5 GB ram recognized/usued by XP).
plug-ins for scope
SpaceF website
SC website
iSiStOy
Re: SCOPE 5.1
Post by iSiStOy »
Heyaa, that's cool news!!
Now I can upgrade my old xp to win7 x64.
Sounddesigner
Re: SCOPE 5.1
Post by Sounddesigner »
But soon
Ralf did tell me in a email that SCOPE's STS Samplers MIGHT be able to take advantage of more Ram in Windows 7 X64 bit, so that's something to watch for when the STS Samplers are available for the X64 Bit version of SCOPE.
The fact that all devices are not available for x64bit beta of scope tells me it was definitely more then just a simple driver write for S|C. I always suspected it was alot of complex codeing for x64bit SCOPE S|C had to do.
I myself was planning on running the x64 bit version of SCOPE soon but i recently installed Windows 7 x32 bit cause i needed a new O/S installment badly thus i probably won't go anywhere near x64 bit for awhile now. Plus i've had my eyes on stuff like the WIVI Instruments rather then large samples loading. I am still curiouse if i will get a little bit better low-latency performance with my computer in Windows 7 x64 but i hate reinstalling all my apps and buying a new internet adapter so i'll probably just stay with Windows 7 x32 bit for a longtime and just continue using and searching for more efficient methods for conserving Ram when working with Native plugins.
EDITED
Last edited by Sounddesigner on Sat Aug 28, 2010 12:30 pm, edited 3 times in total.
babaorum
Re: SCOPE 5.1
Post by babaorum »
Yes it is necessary to remain careful.
Cubase 5.5.1 64 have some problems still, and all the plug-ins doesn't work in it. Just an example : guitar rig 4 doesn't work and freeze cubase 64.
So when all the elements of the chain will be ok, the adventure will be open !
8)
iSiStOy
Re: SCOPE 5.1
Post by iSiStOy »
Good to know! Thanks guys. But for me, it's time to do my part of field testing now, as I'm a bit stuck in the same situation than Soundesigner is. My os is badly in need of an upgrade after years of good services.
microraver
Re: SCOPE 5.1
babaorum wrote:windows 7 32bits is like XP 32 or Vista 32 ,max RAM available for these OS is 3 Go (even if you have more RAM)
Not true, see my attachement i'm using Win7 32 Bit and 6gb ram used by the system , you can see that i use 617 mb cache and have 5099 mb available ,total 6143 mb !!!
this is a trick also used in win 2008 server edition !
Danny.
iSiStOy
Re: SCOPE 5.1
Post by iSiStOy »
what attachment are you talking about? Windows server 2008 trick?
Do you mean some 2008 server R2 "trick" (which is necessarily 64bit by the way)?
Sorry, it's been stated so many time as not being possible and you might have to give some proof of 4->xx GB used in full charge in your 32bit Windows 7 to be credible.
iSiStOy
Re: SCOPE 5.1
Post by iSiStOy »
Let me just add that it's not because you see 8 GB in your 7's task manager that the OS is able to use it.
This is a question of being able to address such memory ranges, with 32bit.
microraver
Re: SCOPE 5.1
iSiStOy wrote:Let me just add that it's not because you see 8 GB in your 7's task manager that the OS is able to use it.
Ok ,here it is ,see attachement or jpeg !!!
Win7 32bit 6gb.JPG (323.79 KiB) Viewed 5126 times
