Sonic Timeworks : Classic Plate released
				blazesboylan
Warp69, I was wondering if you could describe the differences between the 3 types of diffusion for the CD100?  In some early screenshots it looked like they had names such as "thin" etc.  So far I am just randomly choosing one and picking another for the opposite channel so things sound thicker, but it is difficult for me to hear any big differences between the types.
						Hi Warp,
When are the
* Ambience
* Hall
Reverbs expected for release?.
The Plate reverb is top notch and I (as well as others) await news of further releases.
Regards
						When are the
* Ambience
* Hall
Regards
On 2004-09-09 17:35, Warp69 wrote:
Hey,
I'll make a cd100 lite version.
Regarding the delay times in the chorus part : If you choose a delay time above 46ms, like 146ms - the signal will then be delayed between 100ms and 146ms.
The Hall algorithm use more DSP than the Plate algorithm (probably 10-20% more).
The sales have improved, but unfortunately not very much (additional 20-25 items). I promised the following algorithms and will therefore release :
* Plate
* Ambience
* Hall
After that - lets see what happens
Cheers
Thanks for the info...wow both algos are finished! I almost crapped myself when I read that. I still have my $200 set aside for these, can't wait for the release. How is your webpage coming along BTW? As always, keep up the good work....On 2004-09-23 09:31, Warp69 wrote:
@Aries : Both algorithms are finished. I also have the copy protections, but I dont know when I'll release them.
Cheers
I ve downloaded CD100 but it doesnt load on the Routing window, neither as a mixer insert...
When I drag it to the routing window my mousepointer becomes a red X and nothing happens afterwards (it doesnt load, as if I had dragged a Word document, lets say, to the Rout.Wind)
If I drag it to a mixer insert, a preset window appears and disappears instantly and again nothing else happens...
What might be wrong!??
Hey,
The Ambience algorithm will be released very soon - but I have made some changes :
The Ambience will be bundle with the Inverse Algorithm for free. And the Hall algorithm will come with the Concert Hall algorithm.
@rodos1979 : I have no idea why you have that problem. AFAIK you're the only one?!?!?!!? Does any one have the same problem as rodos1979?
Cheers
Cheers
