Yes, I know ´em but ignored for a long time.yayajohn wrote: Mon Jul 25, 2022 8:05 am This is the company that I bought the ZuluSCSI from. (I'm sure you're familiar with them)
http://www.chickensys.com/index.html
I thought they make conversion software only when I decided for CD-xtract and Extreme Sample Converter.
Volumes don´t have to be build.yayajohn wrote: Mon Jul 25, 2022 8:05 am I suspect this is what you need to build a "volume" to be loaded on your legacy AKAI samplers.
Every time you load more than the content of a single floppy disk into the sampler´s memory and save,- that´s a volume.
I have several "setups" for songs I did in the past and their size are up to 32 megabytes,- depending which AKAI I used.
My S-1000 I normally used for drums has 8meg of sample memory.
That was ideal because that was what the samples of the Clavia DDrum III needed.
The S-1100 has 32megs of RAM ...
So a AKAI volume is different size always and cannot be stored into an empty floppy disk image.
The image of a CD ROM is also different.
But when you got "large" SCSI drives, it´s no biggie and you simply store what you want in one, but slow, go.
What free version ?yayajohn wrote: Mon Jul 25, 2022 8:05 am I am investigating the free version to see how "user friendly" it might be before I even think about trying to build my own volumes.
You need nothing to store a "volume" to a SCSI drive.
SCSI is slow from today´s point of view, in the past it was the fastest available.
As long as you use your "vintage" hardware sampler, you´ll have to deal w/ that.
Once the stuff is converted into STS format, you cannot use it in a AKAI sampler anymore,- consequently makes no sense copying to SD card.
