50% DSP, but no placement possible ?
fra77x2
Re: 50% DSP, but no placement possible ?
Post by fra77x2 »
I will try to fix my paypal and we talk then. Of course I have no problem sharing knowledge especially about scope.
Sounds good.
Liquid EDGE
Post by Liquid EDGE »
The only time I start to manually assign stuff is if I run into a run out of sat connection or some other “complaint”..
Though it’s hard to see what’s exactly sitting in each dsp..
So I just assign to whatever dsps that a free/low load until it works. (And remove anything in the project window I’m not actually using, need right then)… if I can’t get it to work I give up.
That’s as far as I go with it. (Along with using the picture of the dsp layout)
So would be nice to know more about manual assignments!!
