Advantages of using Pulsar II/XTC as opposed to just recordi
				Ad Infinitum
				Ad Infinitum
				Ad Infinitum
OASYS has two analog in and outs.  I understand that the analogs can be hooked up to a mixer, but how do you hear OASYS in Logic, so that you can mix within Logic.  I don't want to have to go to an analog or digital board.
For example, say I have a song with Audio tracks, VST instrument tracks and midi tracks. All can be heard using my EMI USB card - vis the Master bus. How does the OASYS instruments and effects get heard within Logic?
I have an OASYS card on hold at a local store - price is $399. I guess I'll give it a try.
Heres an interesting Oasys thread
http://www.the-gas-station.com/messages ... lastdays=5&
Using Oasys with Logic (or any ASIO sequencer) is actually very simple. Oasys has a 12 channel stereo mixer (with sends and stuff, of course). Any of the channels can take a stereo stream from Logic mixer. I think there can be 4 separate stereo streams or 8 mono.
That way you can route VST instruments, audio tracks, whatever into the Oasys mixer and process them further there with Oasys effects. You can simultaneously have Oasys synths on other Oasys mixer channels.
Oasys adds 2x16 MIDI channels that are used to control the Oasys synths, FX and mixer from Logic.
You can record everything back into Logic internally. That is, audio tracks, VST instruments and effects that are streamed into Oasys and everything that the Oasys generates - simultaneously. This is done with a feature in Oasys that routes the outputs of the Oasys mixer into the Analog inputs (without external connections and 100% digital sound quality).
About latency. The Oasys ASIO driver is fine. I can easily get 6ms latency without glitches - perhaps even 3ms. This latency is of course only with stuff streamed from Logic, just as with any good ASIO soundcard - playing the Oasys synths has practically zero latency.
If you can still find the card for $499 think no more, just buy it. It is an unbelievable deal.
