High Optimization CHannels and MB
Support & Discussion for Modular Mixer v2
Moderators: valis, spacef
Re: High Optimization CHannels and MB
Downloaded all my stuff yesterday, are these newer than 11/21/2019?
spacef
Post by spacef »
yes, they are from this morning (zipped and uploaded on november 22 ) :-)
the zips are labelled with "OPTIM" for "optimized"...
unfortunately for you, there are more to come, and you could wait for a final "repack" but can't tell you when (re: anti burn out procedure, need to stop a couple of days here and there to be able to finish the next ones )
plug-ins for scope
SpaceF website
SC website
No worries monfrere.
How many keys for Modular Mixer?
I’m getting the no reg message and I have a Modular Mixer key?
If there’s 2 I guess I better do the key thing again.
spacef
Post by spacef »
the v2 has key 11 (medyx11.dsp)
personnally I always import the keys from another install, or a backup of the scope keyfile.
you have the activation so it must be a new install issue ?
plug-ins for scope
SpaceF website
SC website
Spielraum
Post by Spielraum »
spacef wrote: Sat Nov 23, 2019 12:50 am the v2 has key 11 (medyx11.dsp)
...your info came too late for me
< DSP ReLoading without success
> intel x86, winXP Pro SP3
>> XITE1
>>> scope 5.1
DSP-ERROR after check your Mod Mix devices, without Key, +query cancellation.
Error also after DSP-Folder Rollback :(
on the second same installation on same sytem, there are no problems
but my second installation is not up2date (only for A B comparison+troubleshooting), shit...
i`ve no time+fun to rollback the complete system
please help!
where has Medyx11.dsp entered everywhere?
> scope: ?
> regedit: ?
1000x thx
ron
spacef
Post by spacef »
Hi Ron,
I don't understand the problem.
Modular Mixer v2 needs an activation key, and I changed nothing recently, so it is the same key as before.
It works on my scope PCI here.
I always make a new project , loading the mixer modules first (to know about dsp usage and let scope place the connections where it wants to, and mostly on the same dsp instead of loading them on several dsps because the project is already full of stuff).
If you saved the project and cannot recover your default project, the solution is to rename the faulty devices/folders or move the devices in another location so Scope does not find them when loading the project.
That way, your project can be recovered .
Does it help ?
plug-ins for scope
SpaceF website
SC website
Spielraum
Post by Spielraum »
sorry Mehdi, one must always be guilty :lol:
... i have isolated the problem children. they are temporarily in the BlackList folder...
YOU ARE THE BEST!
\O/
i think, the demo test has probably only triggered a dsp rescan!
:wink: > thanks for that, + jupi, even OSS toys are charging now that complained about it...
i just can not assign the two little devils, maybe one can help?!.
unfortunately, the error messages do not say anything about a source. but for violent escapes they are quite effective :o
...so that was my black friday weekend?
ROCK ON!
spacef
Post by spacef »
I don't know these DSPs, they are not mine. They seem to be in a sub-folder of the main /dsp/ folder ?
not sure what they are for or where they come from...
plug-ins for scope
SpaceF website
SC website
spacef
Post by spacef »
My turn to detect and repair bugs.
The MB 503fx had mixed vu meters and rec channel was reversed :-/
My deepest apologies.
It is now completely repaired, verified, and available here:
https://spacef-devices.com/DOWNLOADS/MO ... PAIRED.zip
plug-ins for scope
SpaceF website
SC website
spacef
Post by spacef »
New Master Bus: MB 403 fx
->Download MB 403
plug-ins for scope
SpaceF website
SC website
Liquid EDGE
Post by Liquid EDGE »
Super. Thanks for optimising them all and the new MB
Just an annoying thing with regards to the optimised routers.. for some reason you have included an extra - in the file name. So I have to tediously change the file names of them removing the dash to overwrite the existing files. 😭 you have including an extra - before the Roman numerals of the file names..
spacef
Post by spacef »
You are right, but only 2 of the routers had that hypen in the name, not all of them if I am not wrong.
Why did it happen? it is a mix of mental fatigue and the will to make it available to users quickly. Also, was not sure whether it should be released as seperate devices, or if they should overwrite the old ones. Then, the relatively high number of devices otimized recently, combined with the fact that this optimzation is tedious, uninteresting and sometimes confusing, led to the unconsistency in the final device names.
I will pay attention to this for the remaining routers. And will remove the hypens on the concerned devices at a later stage, probably when it is fully done and the mod mixer v2 repacked to be put on SC's FTP. Thanks for the heads up anyways.
plug-ins for scope
SpaceF website
SC website
Liquid EDGE
All good man. Thanks. I’m being tongue in cheek but wanted to let you know. Yes it was only a few of them not all.
I’m sure you have a lot on your plate and far more tedious stuff than me to deal with..
I got the SDK and would like to learn it. Got a couple of ideas for things d like to make... if I ever get time.
spacef
Post by spacef »
There was something weird with the wave inputs of MB 403 ... corrected
->Download MB 403
i was thinking of a video tutorial, but I had the impression a lot has been covered in the area. Making devices takes a lot of time (and verifying the devices take some time too....).
There is a difference between makinga device for you and for others. When I do them for myself, generally for testing ideas, I don't really work the look of the panel nor the internals, so it is much faster.
plug-ins for scope
SpaceF website
SC website
I can now load the Routers and Master Bus versions I need and so I started really checking out the new Channels and routings.
Brilliant the way I can use switches and then change the channel routings using MIDI CC#’s.
My last job is Saturday and I relocate and take a break from performing until I find something I like.
Which means Modular Mixer automations and a whole new set up.
I can’t wait to get these back into a project.
Ankyu.
My hardware FX using External Master FX module sometimes need a sample delay adjustment or just have that phasey sound that bums me.
The Master Bus routing options are fantastic for dialing in external hardware.
Even the Warp69 Plate use to bother me but it’s dialed in really well now.
Actually I’m using it from now on since it sounds exactly like a natural ambience.
I have Router Channels 1/2 as my dry no FX channel into the MBus.
Then comes dNa FX Rack, KMA Horizont Phaser, Meris Hedra, GigFX Mega Wah, Strymon Timeline, and Warp69 PlateX.
Fierceness.
Master Bus 502 uses 2 AUX’s but in the project window it shows 3 AUX’s. Ankyu...
spacef
Post by spacef »
Channel S4 has been optimized
https://spacef-devices.com/news/s4-channels/
plug-ins for scope
SpaceF website
SC website
