Matrix Mixer
Re: Matrix Mixer
Just started messing with the AUX one and was cut short by screaming infants.
Man that thing if I am doing this right means each Channel has a Direct Out, which can be used as Sends.
The AUX Returns are the last 4 BUSSes?
That’s brilliant because other devs tried doing it my way which could be right or wrong, but doesn’t matter, and creating the AUXs on each Channel was killing available software ins and outs.
I’ll try this again tomorrow but what a great device if I can run 4 x separate IEM mixes for vocalists.
I’ve already programmed their FX Units in hardware so they run their mic direct into the FX unit.
I don’t really even need to give them FX inside of Scope, except for dynamics which Scope does as good as hardware.
Transient Designer is such a useful device.
Kick drums can into it sounding so-so and come out like a Cannon.
Anyways great mixer Mau, may you continuing having fun with things and making the community worthy like so many others have too.
Man if I lost my XITE-1 it would traumatizing. worse than wrecking your Car.
mausmuso
Re: Matrix Mixer
Post by mausmuso »
dawman wrote: Wed Jul 17, 2019 8:03 pm Just started messing with the AUX one and was cut short by screaming infants.
The Channels themselves don't have direct outs, although you could use the Rec Out to send one channel to the outside world.
All 8 busses have direct outs.
The Aux returns are independent of the Busses and return direct to the Stereo mix only.
If you like you could use any 4 of the 8 busses as Aux Sends and use the remaining 4 as Busses/Sub-mixes etc.
Did you find the Aux Send pots under the checkboxes in the Matrix?
Click the green buttons to expose the 16 sends for each of the 8 busses.
Not the nicest way to do it but screen real estate is limited.
I have also updated the mixer again.
This time to add DSP load switching.
With version 5 you can now switch off the DSP loading of all channels, all busses, Aux Returns and Record Out if they are not required - see the little green buttons across the top of the channels and busses, etc.
I have also unbridled the mixer from loading to DSP 8. 9 and 10.
The end result is the Mixer now loads and works XITE and my 6 SHARC Pulsar card, so I think it will now work on most PCIe Cards (probably not on Lunar Cards).
I will leave version 4 up in the first post, but if you want to use version 5 its attached here.
MatrixMixer Pulsar2 DSP.png (38.23 KiB) Viewed 5436 times
MatrixMixer v5.zip
(2.64 MiB) Downloaded 272 times
Ripper
Re: Matrix Mixer
Post by Ripper »
Thanks Maus.
It loaded without issues. I needed to go out and had to stop testing and couldn't try it soundwise. Will do it later.
Anyway, a BIG THANK YOU for this device as well as for all the work you have been doing for us plugin hungry b*stards! ;)
Peter Drake
Re: Matrix Mixer
Post by Peter Drake »
Brilliant!
Re: Matrix Mixer
I’m babysitting grandkids and Puppy again, I seek abuse.
But all day long I think of routing in my head and can’t wait to see this once I’m relieved of duty.
Scopes routings have always fascinated me.
Years ago it caused me to re route my windshield washer fluid line from the wipers back into the dashboard and out of the ashtray.
Then I filled the Reservoir with Jagermeister.
When I wanted a shot I turned on the windshield wipers.
Great in the winter time, no need for the chilled shot glass.
Thanks Mau I’m feverish to get to the studio.
Re: Matrix Mixer
I’m free at last, going to the dungeon to have fun with the V4/5 of this route master.
mausmuso
Re: Matrix Mixer
Post by mausmuso »
Good Luck
maus
Re: Matrix Mixer
Lots of fun.
I’ve actually got RoyT 16 x 4 for my keys and Matrix Mixer for vocals and IEMs in my project.
I’m going to download v5 today and add automations, then knock out un used Channels.
It’s really nice having Mono and Pan choices per channel.
My input is the only stereo input, the other 7 are mono.
The AUX panel is brilliant really, GUI is not a big deal with me.
Once I start performing everything is controlled from my K4 any way.
Thanks Mau.
Re: Matrix Mixer
Thanks for the updates maus. Excellent mixer keeps getting better.
Peter Drake
Re: Matrix Mixer
Going to get a little cray cray with some feedback modules, and it's all your fault. Thanks for this device.
