MIDI router tool
ronnie
Re: MIDI router tool
Post by ronnie »
Thanks. Sababa! Will check.
the19thbear
Post by the19thbear »
Doesnt seem to save settings here. But the window is bigger:)
faxinadu
Post by faxinadu »
did you click the new button? this is the save settings
http://www.oceanswift.net
Music
the19thbear
Yup. Its not creating a text file in the path that you described. Should I make the path and txt file myself?
faxinadu
Post by faxinadu »
i just checked again, for me the persistency works, can anyone else in addition check plz?
Music
faxinadu
Post by faxinadu »
should look like this once you click the button
Music
faxinadu
Post by faxinadu »
one more things: would simple one-liner midi monitor in between the in and the out be useful to you guys?
Music
Yes!
And.....since you are updating. What about an all notes off button too? (panic)
Great to see you here faxi. hope life is treating you well. :)
ronnie
Post by ronnie »
yayajohn wrote: Wed Oct 14, 2020 11:04 am Yes!
Ditto!
faxinadu
Post by faxinadu »
Thanks guys yes all very good here, Kontakt for the wicked :)
Music
faxinadu
Post by faxinadu »
Did anyone else check the persistency?
Music
faxi; Seems to work fine here. (Win10 64bit) Opened program, resized, selected I/O pushed white button, closed program and opened and settings remained. Initially wouldn't open but that was because my Antivirus (Avast) is checking it out.
That's a great improvement to an already great device. I use this all the freakin time!
Thanks!!!
the19thbear
Weirdness. Does not work here. The text folder along with the text file itsefl is not created
faxinadu
Post by faxinadu »
what if you create an Ocean Swift folder in the roaming folder, does the app then create the rest?
Music
faxinadu
Post by faxinadu »
that's probably what's up! i'll fix it
Music
faxinadu
Post by faxinadu »
@the19thbear can you try this one? ->
Ocean Swift MIDI Router (64).zip
(3.57 MiB) Downloaded 756 times
Music
the19thbear
Working now. thanks:)
faxinadu
Post by faxinadu »
yeep! nice! i will update final version in the original post
Music
faxinadu
Post by faxinadu »
original post updated, please always take the version posted there!
Music
Anyone having any issues opening this due to updated Winblows. When I installed the Microsoft Visual Studio c++ redistributable 2013 edition it started working again. (was getting a MSVCR120.dll missing error)
It was a brand new install
