Few more details: I tried to set the Ada in slave adar in
The sync locked light isn't green.
Do I need to activate the adat A or B depending on which one is used
Of course I tried this, the locked light was in green one time (still no sound)
Do I need to look to other settings?
Thanks!
More inputs
Interference
Re: More inputs
set Scope to master and the ADA8200 to ADAT slave.
use both cables.
use both cables.
Interference
Re: More inputs
Thanks Gary, I think the cables were inverted (adat IN & out are not inverted in the manual?)
Get sound now
Need to investigate for the ada outputs and routing.
Inputs : OK no problem
to get the main mix to the outputs 1 & 2 I assume I should route the main output to the ADAT dest 1 & 2 and plus the 2 XLR outputs to my headphone amp?
tried this and got a distorted signal, I'll investigate deeper.
Thanks all!
Get sound now
Thanks all!
Re: More inputs
yeah.
if your headphone amp has an RCA or 1/4" phone input, chances are that it is consumer level -20. the ADA8200's outputs are +4 professional level, i believe. you will probably need to lower the master on the headphone output from the Scope mixer.
Interference
Re: More inputs
Thanks!
Looks like everything is working ok, the issue probably was the adat cables, they look very sensitive... I plugged everything as explained all is working ok including the multi headphones system, and still have inputs and outputs available for the future
Gary you're the Man!
Re: More inputs
we're men! (i think)
i'm glad you got it going!
Re: More inputs
Hey guys!Interference wrote: Sat Aug 19, 2017 9:23 am Thanks!
I was looking around for an alternative for the a16 and found the ada8200.
It looks to be both awesome and affordable.
Its just what I need, and I think iam going for one.
I wanted to ask if you still happy with it?
Thanks.
Kevin.
Re: More inputs
Yes, but gel the Revive Audio or Black Lion Modification.
It won’t be as good as an A16 Ultra for flexibility but it will sound as good, and the Mod allows more than ADAT In XLR Out, or XLR In ADAT Out.
You can select parts of both and even loop your ADAT which usually costs another 800 to have that capability.
But even if you add the costs of 4 x ADA8200s to a used A16u, the A16 is cheaper.
If you can find a used A16U I would jump on it in a heartbeat.
Interference
Re: More inputs
Still very happy with the ADA8200 since I found the good config for the synchronization. Every stuff are now plugged and I don't have to touch anything else.
This really worth it, I don't know about the A16 but if you can find one it should be probably very good too.
Re: More inputs
Thanks man!Interference wrote: Mon Jan 07, 2019 7:45 am Still very happy with the ADA8200 since I found the good config for the synchronization. Every stuff are now plugged and I don't have to touch anything else.
Ordering one now.
those others suggested i cannot find in my country.
nor a used A-anything.
I think the ada will do just fine, and Iam spending alot less then I initially thought I would for such a box
Thanks again guys, its appreacieteteed.
