Have I killed my 2496 i/o Box??
Re: Have I killed my 2496 i/o Box??
You could bring it to an electronics reparation shop.. They could try to fix it. Of course, it must cost you less than a second hand one...
Hello! I get that all red short flashing.. just connect the box.. open the scope fusion platform, go to settings - routing and click on Hardware IO tab and select the device.. it will be powered and green.
I am not in front of the computer, but I hope this helps
Sorry, no joy
Must have done that a hundred times.
are you sure that the cable is deeply plugged in the luna card and box? It is strange, I had this issue, but solved it by adding the luna z link receive and send in the Hardware IO tab in the settings - routing menu... green light turned on and worked..
Done it all. Different cables. If I push it in anymore the card will come out the front!
