I am totally unfamiliar with the SDK development environment, but I getting ready to jump into it with both feet. Is the following an image of a conglomeration of atoms, and is this what happens beneath the GUI? Thanks in advance!
Roland Kuit Glitch Delay.jpg (133.56 KiB) Viewed 8932 times
The SDK6 is however, to my knowledge, still in an early alpha stage. You can get a lot more done in an earlier SDK. The GUI SDK is then for making a surface, and connect the controls to the pads of the atoms or modules. The GUI SDK however, to my knowledge, is still in an early alpha stage. I can make a gui-module with it, but it crashes the main SDK.
you'll need to look at the Circuit Design part of the SDK manual. That tells you how to connect things. But for design, you'll need to go through the list of *.dsp (atoms) files, and you can general tell what they do by the name, and once you've figured out the "language" you can translate your matlab designs into the atoms available.
Then you start thinking about a GUI...and Graphic Objects (GOs)
jksuperstar wrote:you'll need to look at the Circuit Design part of the SDK manual. That tells you how to connect things. But for design, you'll need to go through the list of *.dsp (atoms) files, and you can general tell what they do by the name, and once you've figured out the "language" you can translate your matlab designs into the atoms available.
Thank you for your rapid reply.
From my understanding and intuition, the SCOPE SDK atoms are tools/modules coded & vetted by ADI (compiled to SHARC machine code) then integrated into the SDK 'wrapper'. Knowing a little bit about how all these items work (together), it must be possible to create another atom (compiled through ADI supplied tools) and add it to the library. However, I'm sure if I am clever enough I can work around with what is already available.
Do you folks know of anyone who has bothered to tear into the SDK to such an extent?
It is not my intention to bump-up against or expose proprietary features, it's just that as a budding engineer who has coded microcontrollers and explored SHARC development as a possible avenue that I arrived at this point. For me, development through the Xite-1 and SDK is much easier to achieve my ends than designing both hardware and software/firmware. So, I understand if a moderator edits my post.
Worth getting in touch with S|C to discuss licencing for the SDK versions. Unless something's changed in the meantime, they are only licenced to owners of Xite hardware or 14/15dsp Scope boards.
I think certain developers have coded custom DSP (atom) files in the past, presumably using lower-level development kits and licencing tools provided by Creamware (as they were back then), but as far as I'm aware, all current development is making use of the various versions of the SDK with pre-built atoms. With the latest GUI SDK (and its predecessor ScopeFX), you are able to take advantage of host (CPU) processing alongside the on-chip (DSP) processing, although there are obviously considerations like latency and bandwidth when doing that.
P.S. There are some very old posts on this forum discussing creation of custom atoms. IIRC, you'll need a fairly expensive AD dev kit (including hardware), plus agreement from S|C to get the dsp files to run on their hardware.
jhulk wrote:for that to work you need a dongle that converts the dsp code to compatible atoms for scope to use
s/c has the dongle for it
but the whole point of the gui dsp is to do the dsp in c++ in the dll file so not needing the dongle
and you have the best of both host and dsp as
I'll be heading in that direction when it's time. My largest concern, as a noob, is that my new code/atom compromises others - the well-vetted and stable codes/atoms the end-user relies upon.
Thanks for all of your replies.
Anyone mess with custom IIR/FIRs and implement them in their SDK projects?
Can one segregate a single SHARC (or even a pair) to dedicate solely to the tasks of a specified algorithm (i.e. can we manually create a 'resource hog' so that it can do its thing without interrupts or sharing)?
w_ellis wrote:P.S. There are some very old posts on this forum discussing creation of custom atoms. IIRC, you'll need a fairly expensive AD dev kit (including hardware), plus agreement from S|C to get the dsp files to run on their hardware.
convoleq is using sys files_
for low latency
convolveq as well as analyzer are doing ffts btw;
eric made a sys file host based fir filter that is included free for customers in the convolveq.zip
dsps are made for fir_
you can do the readout multiply add in 1 circle;
1024 taps could be realized on 1 old dsp at 44k1
Coding in C++ seems the easiest (and least expensive) at the moment, although, I don't believe I have ever converted a prog into .dll so that will be fun. If I needed greater efficiency and possible robustness then atoms become more useful (theirs or mine: if they work hahaha)...
How much memory do we have at our disposal onboard the Xite-1?
Are there atoms available where I can enter mathematical equations?
Are there atoms available that can perform Newton's Method of Approximation or other such methods?
1024 taps, I should be able to do something sophisticated with that, eh?
if your going to compile into a .dll you will need the guisdk and compiler of your choice vstudio is recommended for pc then you can use your own class library or one of the others juce vstgui
you can create your c++ algos and then interface them to use sync and async pads for the scope dsp,s and a gui interface for the controls
once you have compiled your .dll file it then can be added to the module list and you can then wire it up using the sdk
you will need the sdk 5.1 is very stable and would recommend asking for that version as sdk6 crashes
ask gary b about the sdk for the xite and the guisdk beta
then go to bcmodular and ask sharc to join the sdk developers forum
there are several developers working on the guisdk as its a new avenue to lots of them and theirs a wiki being created about it only for developers
explaining the atoms list and various how to,s
and the master that is tgstgs also frequents with his vast knowledge
Happycritter, atoms are already compiled code, they don't have interpreters or compilers in themselves, so no, there isn't anything to just type in a math equation. I think matlab can export C code, but you'd probably need a special license for that. But I wouldn't worry about that yet...the atoms do have a lot to offer, and you can get most things done there.
What SCOPE SDK does is take your circuit design, of graphically connected atoms, and links those into a device or module. Think of the SDK as a graphic programming language. That's for the DSP end of things. For SDK 5.1, there are also scripts and other ways to run on the host/PC aside from atoms. But they are more or less completely contained within the parent process of SCOPE.
What the new SDK6 and GUI SDK offer is APIs to run your native code in any way you like. They suggest JUCE, but that's not the limit. Graphical programming of DSPs using atoms is still mostly the same.
Really, you can get most objectives accomplished in Modular. The SDK takes it to a lower level, and let's you use all the atoms available to make an optimized device for scope fusion, or a new module for use in modular. Many atoms exist as a modular in Modular. Then there's the dongle/gui sdk approach that allows you to write your own DSP code. It is very much worth while spending time in Modular first, since you will get to understand the system rules, such as how polyphony works, how to deal with feedback paths, and even various data type connections available. These rules more or less apply to the SDK graphical language as well. By the time you get to writing assembler code, you will understand what you can and cannot do.
