Pressure - monosynth (can be used polyphonically too)
Re: Pressure - monosynth (can be used polyphonically too)
As I said the MIDI works fine, the XITE-1 often loads Modular with audio silence, usually fixed by loading a preset, or moving the Poly 1/2 slider.
I'll just rebuild from scratch and see wassup......
Ankyu
Post by JoPo »
I don't get any sound, here. Midi is ok but niente output.
I tried to check with a vumeter inside modular to see where the sound stops and after the Sw3-1s module, I don't have any signal.
Shroomz~>
Post by Shroomz~> »
Strange because it works fine here. I'll check into it in the coming days and get back to you asap folks.
ShogunSpy
Post by ShogunSpy »
Works for me!
Mon Frere Jopo....
Rebuild from scratch. This will help you memorize the design and it's just good practice.
Shroomz was right about the MIDI Channel.
At first you see a MIDI module that says omni, but there's the MVC B just a few modules below that is MIDI Channel 7.
After rebuilding I discovered this, but during the rebuild learned a great deal as I made each encoder group their own color, and studied the design.
As usual, I learn the hard way, but frustration and anger are excellant motivators for me, and being humbled by stupidity is a great reminder as then my cockiness, subsides for a week before returning to my asshole self.
So this was a multi purpose patch which works perfectly on MIDI Channel 7.
Ankyu
I do have a question though about the MVC B.
I love the way the connector jacks always color themselves when occupied, but I wish to know what might be connected to the yellow covered jack, as I see no cable.
And secondly what is GIT..?
Thanks in advance.
Shroomage 1.png (359.15 KiB) Viewed 5516 times
Post by JoPo »
You're right ! I didn't see it either. :D
sharc
Post by sharc »
dawman wrote:I do have a question though about the MVC B.
MVC B has a GUI bug. The connection indicators don't show correctly. I'll fix it for the next update.
The yellow covered jack you mention Jimmy is for Portamento/Glissando Mode control. The one next to it labelled GlT is for Portamento/Glissando Time. You can see these long names for all connectors in BC via the tooltip when you move the mouse pointer over them.
Shroomz~>
Post by Shroomz~> »
Glad you got it going guys. If you download the version I posted for Paul in the music thread here - http://forums.planetz.com/viewtopic.php?f=17&t=32028 you'll find that the synth loads with both midi channel settings at Ch 1 so it's ready to go on Ch 1 without having to make any changes. It also loads with the sound used in that track which is a pretty nice sound.
next to nothing
Post by next to nothing »
Guess I should edit my post then, apparently it didn't help anyway :)
Shroomz~>
Post by Shroomz~> »
next to nothing wrote:Guess I should edit my post then, apparently it didn't help anyway :)
Hi mate, I edited the first posts because I put a link to here on a techno forum yesterday. Kinda doing this in a rush because I'm busy with other stuff. Did you suggest something that I forgot about like setting it to load with the midi on omni or something?
ShogunSpy
Post by ShogunSpy »
Shroomz~> wrote:Glad you got it going guys. If you download the version I posted for Paul in the music thread here - http://forums.planetz.com/viewtopic.php?f=17&t=32028 you'll find that the synth loads with both midi channel settings at Ch 1 so it's ready to go on Ch 1 without having to make any changes. It also loads with the sound used in that track which is a pretty nice sound.
yes! I can confirm that the Synth in the above link works for me. thx again
next to nothing
Just the things you quoted in your third post :)
Shroomz~>
Post by Shroomz~> »
next to nothing wrote:Just the things you quoted in your third post :)
Ok, well I don't know what it was any more. Sorry bud, the thread pretty much went tits up when I thought I had found that poly bug and panicked the other week.
next to nothing
Shroomz~> wrote:
next to nothing wrote:Thanks, looking forward to test this :)
If people struggle to get sound and are unfamiliar with bc modular,the MVC module is set to channel 7 by default :)
It sounds better on channel 7! 8)
No worries mate :) and by the way the post is still on page one, was just a friendly tip ;)
faxinadu
Post by faxinadu »
downloaded thank you
http://www.oceanswift.net
Music
Shroomz~>
Post by Shroomz~> »
Update: new version with 2 bugs fixed as of 30/06/2013.
Download and bug-fix info in the OP.
ShogunSpy
Post by ShogunSpy »
AnKu!
53E7
Post by 53E7 »
When I loaded the new version Pressure9 for the first time, Scope asked for the location of Pressure.pre I just saved a new preset of the synth (as-is) once it fully loaded and the next time I loaded the synth it loaded fine.
It seems the current patch is the preset you used in your track Voyant. Is it that same patch? Thanks so much for sharing!
