Motherboard that will hold 3 x 15dsp Cards ( Powerpulsar )
Re: Motherboard that will hold 3 x 15dsp Cards ( Powerpulsar
Ok yes , that's exactly what happened . got stuck w the v5 Sonic Core drivers and that's messed things up .. Then I went to do a system restore and lost XP SP2 and my graphics driver in the process ...aaargh ! yes it's a new build so that might be the way to go . One thing I don't get though Gary... the v4.5 Installation ( unzipped ) Setup will not run ... it was the first thing I tried to install ( and with ASPI 4.70 installed ) before I tried all this v5 and v4.0 stuff but nothing , Setup just won't run . What the ??! do you have that 4.5 zip somewhere ?
probably. pm me to remind me to dig it up. the actual program is 100% identical to v4. there were no bugfixes and the only new device was the SBC.
Actually Gary I have the v4 Scope disc here ..so in that case I'll try from this now . Thnx for your help
M
no problem.
i actually uploaded it here:
https://www.filesanywhere.com/fs/v.aspx ... 6671baa867
i tested the installer(setup) before uploading it, so it definitely works. this link is good for 5 days.
a really stupid questiom...
you did unzip the folder first before trying to use it, right?
Yes I had unzipped it
strange what happened .
Anyway I've since got everything working now from my Scope 4 disc and 45dsps are showing up in dsp usage ,
so back on track here .
I will go and get yr v4.5 ( I didn't know it 's same as v4 ) thnx for uploading that for me .
What is the difference between Scope v4 and S|C v5 ? ( I'll be staying 32bit for now )
Cheers , M
Cheers , M
well, a lot, but it's still Scope as you would expect it to be.
new plugins, most plugins are now stock and a minor redesign of the gui are on the surface. under the hood, things have been redone. there might be a couple more bugs than in v4, but overall v5.1 feels more solid and the new plugins are excellent. i'm using it myself and i don't miss v4. if you move to windows 7, you'll need v5.1. if you stay in xp, it's a good upgrade with a new driver and software and you also support the company that is keeping Scope alive.
no problem on the upload... use it if you need it.
Ok great , I'll get the v5 from SoniCore ..we must keep that platform going .
Is Ralf there now ? I heard he was back ... Cheers , Michael
That's great I'll give him a call .
by the way ,,, I downloaded yr v4.5 thanks for that .
I had v4 happily installed and tried to bring in the DSP / Presets / Devices folders in from my old hard drive v4.5
but somewhere a path is lost and Scope runs but wants to close ,, clearly this is Not the way to do it
So I uninstalled my v4 and went to run yr v4.5 ... when I try to run Setup nothing happens ... again !
I don't get this ?? I installed v4.5 years ago no probs ??
M
M
Ok .. I sorted it ... needed to remnants of previous install , and run new install from C drive . cheers .
