yea, it is the most surgical frequency tool in scope..
the draw tool needs to be fixed... misses some moves
also... what about the latency. could it be avoided somehow?
also...... sorry for my stupid question but.. what is the main philosophy of it? effect basically?
ConvolveQ
- ARCADIOS
Music Manic
Re: ConvolveQ
ARCADIOS wrote: also...... sorry for my stupid question but.. what is the main philosophy of it? effect basically?
That's what I was thinking. Looks like it can separate frequencies with some serious sharpness.
Would be great for extraction.
tgstgs
Re: ConvolveQ
thank you very much for the first point;
but its also the answer to your last point;
use wherever other eqs fail_
the prinzip is:
collect some samples;
do a fft;
calculate filter;
convolute filter with audiostream;
da a ifft;
the first step is what makes the latency;
the better the frequency resolution - the higher the latency;
there is no way around this_
but its a mastering tool so latency should not matter_
the drawtool is sending async signals;
if you move faster than the asyncupdaterate you are able to /jump/ over a band or more yes;
but a cosmetic surgeon does not move too fast with a scalpel either;
//i hope at least-
good vibes from vienna
the prinzip is:
do a fft;
calculate filter;
da a ifft;
//i hope at least-
tgstgs
Re: ConvolveQ
thanx to all who bought convolveQ
there is a free plug for all convolveQ owners;
check it out_
http://www.digitalaudiosoft.com/news.html
_
good vibes
check it out_
_
good vibes
- Ricardo
- garyb
- Moderator
Re: ConvolveQ
what are you trying to do?
equalize an effected sound, or effect an equalized sound? or use it as an effect?
the answers to the above questions tell you where to place it in the chain.
or is there something i miss?
- Ricardo
Re: ConvolveQ
Nicely put. I was just wondering whether to put it before a mastering device such as optimaster, or after, as it is pretty transparent
R
- garyb
- Moderator
Re: ConvolveQ
personally, i think the main purpose of a mastering compressor is the maximize the loudness, or reduce the dynamic range of a track so that it plays well on the common playback systems. i would want to have the piece equalized before that final step. if you're talking about mastering, the idea is to remove bumps in the response to get a flat reading from about 60hz-8 or 10k, or something in about that range. that way you get listenable playback most anywhere. this is as opposed to using an eq as a sound sculpting effect. i'm sure that it can be used either way.
that's just my thinking. whatever works well is good. limiting the track will make certain things pop out a bit more, but i think if a multiband radically changes the frequency balance, then maybe you're not using it correctly. for that reason, i don't see a purpose to re-eq the track after the final limiter stage. then again, if it sounds really cool, who am i to judge?
- Ricardo
Re: ConvolveQ
Grest advice Gary, thanks. I'm now thinking of all the uses it may have, in the studio and live!
R
tgstgs
Re: ConvolveQ
_
sorry this is no live tool;
it is for mastering and postproduction;
good vibes
good vibes
- Ricardo
