SCOPE 5.1 + XTC backwards compatibility
babaorum
Re: SCOPE 5.1 + XTC backwards compatibility
Has Someone tested XTC mode with cubase 5.5.2 (32 or 64) in windows 7 64 for PCI cards ?
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
- ARCADIOS
XTC works in windows 7 64bit and 32bit Sequensers, and all plugins work fine.
BUT
XTC DOES NOT work in Windows 7 64bit with 64bit Sequensers or any other 64bit audio application as Synthogy Ivory II standalone 64bit. TOO BAD
ASIO4ALL works.
BUT
ASIO4ALL works.
- garyb
- Moderator
Scope asio works with 64bit sequencers. it works just fine.
babaorum
I know but I asked on the XTC mode because I'm very interrested by this mode , I think it makes available the routing only in one soft (like cubase) and the qualities of plugs S/C, and with less hardware outputs (because actually I use only a stereo output in main mix) you can load more plugs in the scope and use the cubase routing for the multi-output buses. It could be great to have XTC on a 64bits sequencer in win 7 64 and I dream about use an SSL channel strip with a vinco on the same insert track in cubase !garyb wrote:Scope asio works with 64bit sequencers. it works just fine.
