It works now; no clicks or pops a the lowest latency setting, and the system isn't optimized for audio; checked with one track only, though.
Thank you very much Widy. I didn't even considered the registry key you suggested...
Do you think it's a Vista related issue?
Reaper 3.74/64 and ASIO Scope (v5.1 - PCI) error [SOLVED]
Re: Reaper 3.74/64 and ASIO Scope (v5.1 - PCI)
dont know .. i use win7 on an ssd ..and it rocks like hell ..never tried vista ...Cochise wrote:It works now; no clicks or pops a the lowest latency setting, and the system isn't optimized for audio;
vista is more or less a win7 prototype os
i also setup at low latenzy ... but if u use more than 20 tracks in reaper in combination with vst's
1 ms is to low .. and u will receive noise during asio .....
i setup 6 ms
lg widy
Re: Reaper 3.74/64 and ASIO Scope (v5.1 - PCI) error [SOLVED
Right, I'll check that soon.
Thanks to you all, guys. Garyb and Pollux gave me the right input and your infos Widy have been resolutive.
Sonic Core certify 5.1 x64 for Win 7 only, not for Xp and Vista. Maybe the installer didn't properly recognize the OS version for older Windows, and sets 32 bit Asio dll in the registry
Naaa... it's a weak argumentCochise wrote:Sonic Core certify 5.1 x64 for Win 7 only, not for Xp and Vista. Maybe the installer didn't properly recognize the OS version for older Windows, and sets 32 bit Asio dll in the registry
It's just strange...
