hey did anyone get it working on 5.1 scope pro boards? I have 3 boards in the system and while it tracks I have dropouts and clicks when syncing cubase 4 to vdat, strange behaviour, any suggestions?
edit: solved, I just had to connect vrc-s to the asio driver and vdat, with vdat connectin the asio module I only got dropouts etc.
						is VDAT working on v5.1 ?
				Music Manic
Re: is VDAT working on v5.1 ?
Does anyone have Vdat working in v5.1?
I remember that someone said my "exception errors" was down to Dual Core.
XBox version is working for me, but I just record and playback, nothing fancy,,,,
Same with Xbox-D ... Working on XP32
				Music Manic
I've just realised that I was using the beta version.
All seems ok so far. I've been away too long!
ripped some оld ADATs from XT last week!
even the sync input works as we can see.
however, sync output from scope doesn't want to go as discussed earlier on viewtopic.php?p=321742&hilit=savastatsync#p321742
i wonder if it's fixed in V7
also, i suspect that VDAT would give blue screen on recording / playback under windows 10 and newer - is it true?
oh, i see the image has been mangled beyond visibility so i must reveal the system - windows server 2012 r2 without KB2919355 update
... and the project was ripping ADAT to VDAT in sync, and at the same time a rough mix was being done for monitoring and also was bouncing to another VDAT... interestingly, VDATs didn't want to be cascaded from the same clock and even threw some error that it can't be done but nevertheless functioned AND the second VDAT was also in sync with the first one and the Alesis deck!
Imho that‘s just a visual flaw. If the Adat Sync is received once, it‘s applied to all devices in the chain automatically.pranza wrote: Tue Jun 27, 2023 12:56 pm ... interestingly, VDATs didn't want to be cascaded from the same clock and even threw some error that it can't be done but nevertheless functioned AND the second VDAT was also in sync with the first one and the Alesis deck!
Congrats for your succes
