If you can, compare the contents of the two files (change their names to cset.txt and open with simpletext). If they are the same, don't panic. If they are different and nothing special happens with your pulsar - don't panic, too. One of the rules of the thumb is to have the cset.ini back-upped to replace it if necessary (the file gets corrupted from time to time)On 2002-01-11 09:17, Gregory wrote:
And strangely when I changed the main drive and reinstalled Pulsar the "cset.ini file" in my Pulsar went from saying it was 153 K in size to saying it was 4 K in size. I don't know if that's bad or good.
Optimize Your Mac For Audio
				samplaire
Also some more Mac tips & tricks from another thread in the tips & tricks forum:
http://www.planetz.com/forums/viewtopic ... &forum=3&2
				samplaire
hi,
I found what exactly was the cause of my Cubase-launch frequent crashes problem (described earlier in this thread) and want to share it with you (perhaps this one will be fixed in 3.1 but...). The problem lies inside the "Luna Midi Source" module - it is 'active sensing' sensitive and can crash your sequencer with the 2 or 3 error or #10 bomb error. The situation occurs only when you have the 'Luna Midi Source' module in your project: "Pulsar Midi Source" module is free of that bug. But if you arte forced to use the module (have Luna II only for instance) - try the workaround of having the OMS app open during your whole Luna session - it really works. That may explain the absence of this kind of problem in Air_Pollo's system...
I also prepared a rather complete guide on how to optimize your Mac for smooth Pulsar/Luna operation - you can find it here: http://www.planetz.com/forums/viewtopic ... &forum=3&0
Sam Plaire
<font size=-1>[ This Message was edited by: samplaire on 2002-04-19 13:46 ]</font>
<font size=-1>[ This Message was edited by: samplaire on 2002-04-19 14:01 ]</font>
Sam Plaire
i just had a quick browse for a display card.  AGP seems to be better than PCI.  my first search results were going in the direction AGP is not possible on my mac G3.  is this correct?  anyone care to explain what AGP is and it's advantage compared to PCI (better reverb results seems obvious)?  it's about time i get to know my machine a bit...
a good link will do too of course.
thanks
thanks
andy
the lunatics are in the hall
AGP: Accelerated Graphics Port - this type of connection generally has its own bus and therefore (depending on your motherboard's implementation) does not share bandwidth/traffic with the PCI bus, freeing it for other tasks (reverbs/delays! etc)
Edit: Here's a great link to learn more: <a href=http://www.agpforum.org/faq_ans.htm>check it</a>
<font size=-1>[ This Message was edited by: subhuman on 2002-04-19 22:49 ]</font>
thanks sub!
i got a litlle further now. i've seen the ATI Radeon mac edition, but it's for 'AGP-based macs'. i still haven't found out if my B/W G3 has this quality... i suppose not. most testing was done on G4. nVidia is for sure only for G4.
there's the ATI Radeon 7000 AGP, 64MB (see link), but it's a bit confusing to me. it's for older macs without AGP slots to work on PCI, but do i benefit from this concerning audio performance?
mmm
http://computers.cnet.com/hardware/0-11 ... 10957.html
mmm
andy
				samplaire
Hi Andy,
According to the Apple spec. library ( http://docs.info.apple.com/article.html?artnum=43123 ) your blue & white G3 has got no AGP port... As Subhuman said, AGP port brings your DAW some benefits (AGP video card doesn't disturb the PCI bus allowing more reverbs to work etc.). I believe my Mac was the first to have AGP port (G4/400/AGP - there were earlier versions of G4/400 with PCI graphics, too)
Sam Plaire
<font size=-1>[ This Message was edited by: samplaire on 2002-04-20 14:33 ]</font>
Sam Plaire
				samplaire
Here's a tip for Nuendo users (and probably others, too) http://www.planetz.com/forums/viewtopic ... forum=19&0
						Hello.
I recently bought a Pulsar 2. I'm now using a Mac QuickSilver G4 at 933 MHz, single cpu, with 1GB RAM, running OS 9.22. This OS works just fine with the Pulsar 2. I've started optimizing the system a few weeks ago and right now the Mac needs just under 20 seconds to boot (from the moment of pressing the powerkey until all the internal drives are ready in the Finder desktop). I've disabled a lot of extensions, including the internet and tcp extensions, location manager and multiple users etc. Besides OS 9.22 the following software packages are installed: Pulsar SFP 3.1, Cubase VST Score 5.1, Peak TDM 2.6 and OMS 2.38. I'm about to begin working on an installation guide for this combination. Anyone got any comments? The system is stable and runs very fast. The SFP 3.1 software runs better and faster after I disabled just about every extension possible. (I've got a regular networked system install on a different partition.) Personally I'm quite happy about the performance of the package alltogether. The only thing I don't like about the SFP Software is the font (typeface) it uses for parameters and info. Is there any way to change the built-in font for a Geneva or something?
Regards,
dodge
Regards,
dodge
 Sir
 Sir
