In fact for my ASIOs pb it was my cubase project wich was full of plugs ...
I will test again in a near future the 5 version,
sorry,
Baba
Scope 5.0.2615 bug
babaorum
Re: Scope 5.0.2615 bug
Sonic Core Luna II + Pulsar II scope v5.1.2709-x64, Cubase 9.0.20 (64), Pro Tools 12.7, Wavelab element 9 (64), windows 8.1 pro (64), Asus P6T 18Go RAM core i7 920, SSL Duende Native - Lexicon PCM Reverb Bundle - Waves - Sonnox
Mydriasis
I have installed the latest version of Scope 5 and the Modular cables have returned
The Miniscopes are still invisible although i cant say im likely to use them when i have Minimax. So i dont really mind
- erminardi
not for all modules... for example the first MODII patch (3 osc sequenced) is still unwired in my systemMydriasis wrote:I have installed the latest version of Scope 5 and the Modular cables have returned![]()
Only when you drag Miniscopes. When they are still I can use and see all.Mydriasis wrote: The Miniscopes are still invisible although i cant say im likely to use them when i have Minimax. So i dont really mind
Mydriasis
erminardi wrote:not for all modules... for example the first MODII patch (3 osc sequenced) is still unwired in my systemMydriasis wrote:I have installed the latest version of Scope 5 and the Modular cables have returned![]()
Oh i'll check all the MODII patches and see if mine are the same.
Both Miniscopes are invisible except for the knobs from the minute i load them. In fact its not that the body is invisible, its just not there at all
YedOrium
+ asio 32bit problem too (I miss the very stable asio 24bit with sonar, asio 32bit=crack and synchro problem...)
Yed
Jah Servant
I noticed if you load in an old project where you used the asio 24 bit modules then they will be there however they aren't available in the menu, I couldn't really understand that one. Since I always started with my default project it wasn't a problem, they were always there.
YedOrium
We'll see.
Yed
- garyb
- Moderator
Sonic/Core did NOT exist 5 years ago....YedOrium wrote:I report the Miniscope and Miniscope MK II problem two versions of scope 5 ago ...
YedOrium
- garyb
- Moderator
keep letting them know, they do care...
