ASPI drivers can be downloaded here
or here
information on why aspi can be found here
But more specificaly in the manual which can be found here
Hope this helps but try other things too
I think aspi is specifically to do with audio and not midi or graphics
Midi-problem?
Re: Midi-problem?
Thanks for the advice.I've found out that the problem comes from Cubase 4 and 5 with multicore Cpu. A simple Cubaseproject ; 1 audiotrack ,1 plug-in(reverence) gives glitches.The asio time usage turns wacko but in the performance section in tasks gives a stable Cpu-usage (10%) for all 4 cores and a low memoryuse.The ulli is 3ms on 48kHz.
3Gb patriot memory - Q9550 - intel mobo Dp35 - nvidea GF 8400Gs - Xppro - 2 x pulsar2 - 2 sata Hd.
Grtz
Marc
Grtz
Marc
Re: Midi-problem?
all of these problems will be solved with scope 5.
Re: Midi-problem?
I've told my problem a few days agoo on the Cubase.net site and much did read it but no-one replys.It's frustrating to invest in fantastic software and hardware and when something doesn't work ,there is no satisfying support.The most help i get is in this PlanetZ site.
Thank you
Marc
Thank you
Marc
Re: Midi-problem?
after installing scope5 all problems are gone ; no glitches,crackling and pops no more .Midi works fine.
Thanks sonic core
Thanks sonic core
Re: Midi-problem?
Good to hear!Have fun.Popheadpoepie wrote:Hi,
Thanks sonic core
Re: Midi-problem?
Yes, that's good!
Did you make intensive midi tests for that? You just installed v5 and gone?
Thanks in advance,
Thanks in advance,
Re: Midi-problem?
I've re-installed several times scope 4.5 software and drivers ,even cubase5.The result was always irregular behavior of midi.Using Wave destination gives pops in wavelab.Using sts-3000,4000,5000 gives pop and glitches.
Updating to Scope5 and testing all this gives an amazing result.Everything works great.
Grtz
Marc
Grtz
Marc
