creamware card 15dsp cause global warming
Re: creamware card 15dsp cause global warming
stardust wrote:You tend to trust more in the proof of cooling than in the proof of warming by the same figures.
Now you put it like change is there all the time.
Thats easy to agree.
Lets see if the home made changes are bearable.
human greenhouse gasses account for about 1/10 of 1% of total greenhouse gasses. that's a pretty insignificant amaount. i'll grossly over-simplify for you. let's say that temperatures rise 100 degrees from such gas activity(which is bullocks). then the human amount would be 1/10 of a degree.
i don't "trust" in cooling. :lol: the thermometer shows that temperatures are down. i don't deny warming has/is occured(ing). the earth has been much warmer at other times, for example about 400 a.d. when Europe was so warm that houses were built without indoor hearths. i expect it to reach higher temperatures in the future. no amount of governmental action or carbon taxation will change that.
here's a REAL place that human activity warms the environment: concrete. large amounts of blacktop and concrete act as an a heat sink. they hold heat and release it slowly. the local area around concrete and blacktop is definitely warmer than areas of natural land or plant life, as anyone who's traveled on a motorcycle knows. the efffect is only localized however. if the thermometers are in rural areas, they tell a much different story than if the thermometers are in a city. cities are a miniscule part of the earth's surface, however, even though to the city dweller, the city seems to dominate the earth. as i pointed out before, all 6 1/2 billion people fit in the state of Texas with 1100 square feet per person.
at0m wrote:Removable HEPA filter? Worn panty's will do for me :D
If I have the HEPA filter, it comes with the case. Your solution is probably better. This is just a plastic mesh filter that's on par with the ones we have in window-mounted Air Conditioners these days. I'm also into 'positive case pressure' these days as it helps keep the dust at bay from all the cracks in the case (front drive bays, optical drive slots, seams where the case door meets the case, etc).
next to nothing
Post by next to nothing »
Yeah, 100 years is a drop in the ocean of the huge system natural cycle. Just like the heat generated by 15DSP's is nothing to get XCITE'd about when we look at what's coming.....
I got 12 DSP's but theres space between the sharcs in the rising oceans.......
tomylee
Post by tomylee »
back to topic guys...the numbers can'T be right astroman! (I hope they are not...)
If a sharc under full load would really take 10watts, my new 36dsp 3 card system would use 360 watts, I also have 3 Uad cards which also use quite alot (compared to uad-2) then an overclocked core2duo graphics 9600gt and well, 2 hds ...
and all this with an almost stilent 450W high quality brand power supply...
I hope Im not surfing the edge here already. I occasionally had crashs with my 21dsp system before under full load, I hope my psu is not too weak...
but still cant believe a sharc takes 10W, that seems alot!! a uad-1 which has one chip gets waaay hotter than any of the sharc chips in idle as well as on full load! and it uses for the whole card only 15watts, AND has a passive cooling attached to it.
suppose one sharc (old ones on home project and pro) used really 10 watts it would literally get freaking hot, too hot imho! i guess 2-3 watts under full load is a more reasonable figure...
astro, where do you have remembered those numbers from?
tomylee wrote:astro, where do you have remembered those numbers from?
http://www.ipcc.ch/
tomylee
Post by tomylee »
http://www.ipcc.ch/
lol you took the sharc power specifications from ipcc? ^^
Post by jksuperstar »
a whole 15 DSP card cranking at full load will probably run around 25W (~1.5W max per DSP).
compared to an XITE-1, where each DSP could hit 1.75W max...but I can't get it even near full load.
tomylee
Post by tomylee »
jksuperstar wrote:a whole 15 DSP card cranking at full load will probably run around 25W (~1.5W max per DSP).
jep, the environment gui workflow seems not yet optimezed for this amount of power...working with modular these days alot I noticed it would be nice to be able to load 10 oscs with one click just like you can set the number of tracks you wanna add in cubase for example, would help alot. Also very many time saving auto connect features would be nice, would enhance workflow alot!
edit: thanks for the numbers! Thats what I thought! :)
tgstgs
Post by tgstgs »
do caulking all holes in the case where no fan is mounted;
let only the fans (blow IN/OUT) do their job;
that gives much better temp results inside;
tested with a chieftec bigtower;
power/life;
i take any bed your boards life longer than anything else in your daw;
V8 vibes to improof the glob. warm.
ChrisWerner
Post by ChrisWerner »
garyb wrote:i might as well go all the way off topic.
CO2 is VITAL to life on earth. the more CO2, the more the plants grow and the more oxygen there is to breathe! more plants cool the temps, all part of the cycles.
GIVE ME MORE CO2!!!!
Get some! ;-)
http://www.greenfacts.org/en/co2-captur ... /index.htm
That reminds me on sweeping something under the carpet.
How about installing a pipe system at your DAW and directing the heat to a underfloor heating?
tomylee
Post by tomylee »
garyb wrote:water vapor is the main "greenhouse gas" at 95%. human CO2 production is about 3-5% of all CO2 in the atmosphere. that's about .117% of the total greenhouse gasses(CO2 is about 3.6% of all greenhouse gasses)
I dont know where you have this numbers from, but they are exactly the same as I had 10 years ago in school, we were talking about climate change etc and had a book which told us that volcanos were the largest contributor of co2 in the air, which were 3% of the greenhouse gases, concluding that the man made influence on all this was 0.115% (im not sure if it was 0.115 0.0115 or 0.00115 but I still remember the last 2 digits were 15 and it was way way smaller than 1)
Now I can tell you why I remember this so well...
well..when we read this, nobody really seemed to notice, but i was completely buffled and stared at the teacher who looked at me like I was firing a bullet any second, so she watched me and probably expected me to say something, cause she saw there was something going on in my mind, and teachers seem to like if they dont have just zombie eat it all raw students... ;)
me: "but miss xyz, but that literally means that all thise climate stuff is really just irrelevant?!" my expression was like why in hell would anyone lie about something like that, and back then, I was 16, I could not even immagine that anyone would lie ever in science world, after all its science and claims had to be prooven before being accepted...
teacher feeling a bit uncomfortable slowly starting to bring up an answer while her face turned out to give some resigning stony cold expression:"well yes, probably yes thomas" after that se quick as lightning continued to do her stuff that she had been doing for years, if not decades as a teacher in our schoolsystem, probably she felt uncomfortable to question something that she had told probably generations before me...
In the same moment I turned myelf around on my stool and watched aroun in the class to see if anyone had any mirror neurons to show for my exitement about this...
but big FAIL - nobody, all pretty tired, noninterested passive schoolzombies, waiting for the hour to be over and ultimately waiting for their lives to be over...well at some point I had to feel with them, after all its not their fault, it is parents, it is society which made them what they are supposed to be made: a gear in a system whose only goal is self perpetuation.
sad as f. but hey...nice story wasnt it?
after all my teacher told me tha all the climate hazzle is just based on nothing more than wrong measurements and intentions, far away from science, it even hurts science as we know it today, or shows its fragility...
thats why I remeber all this...
Get some! ;-)
the heating idea is good. :lol:
the CO2 storage thing is stupid. more than 95% of all "greenhouse gas" is water vapor. human co2 is a tiny(less than 10%)portion of the 3% or so co2 "greenhouse gas". brainwashing dies hard...
yawn.
it's not my theory.
neither is the end of a small ice age in the mid 1800's.
there was a HUGE climate change before those 150 years, called the little ice age, that even spawned Viking raids and a frozen Thames. this isn't my theory either.
as to the ethics of petroleum usage, that's a wholly different discussion. you call me when you stop using such products. don't touch your computer.
ChrisWerner
Methan Hydrate German only, sorry.
Methane Hydrate is locked by pressure underwater at the continental slopes -500 to -2000 and more meters.
But when eruptions and increase of global temperatures happen the Methane Hydrate will raise to the surface and the Methane is set free.
There is 200 percent more Methane Hydrate than oil, natural gas and coal together.
When 1 volume of Mehane Hydrate is set free is will blow up to 164 times of Methane.
Methane Hydrate has a factor of global warming 1 to 30 compared to CO2.
And you know when it is set free, it will get warmer, more is set free... round and round...
We had this before when the dinosaurs vanished.
Conclusion:
Let us use our cards as long as we can.....
And imagine:
Two planets met in space, one to the other, "how are you ?"
"Oh, I am ill, I have Homo Sapiens"
"Oh dear, I had them too, but relax... this will solve on its own."
...and is made of petroleum and uses petroleum and other "fossil fuels" in manufacture. also it uses rare and toxic metals, but i'm not mad at anyone for using one.
Chris-the earth is fine with people on it. people are not a mistake, even though they can be really stupid.
tomylee
Post by tomylee »
btw the best psychomental conditioning is to tell one he is bad, telling him he is bad and continuing so makes the subject prone to suggestion and thus guidance.
If there is a higher level reason for all this climate change nonsense (just as high level as the religious effect), then It is probably to control people, to make them susceptible for orders.
Just think a little kid...if it does not do any wrong and you continue to tell it it does something wrong, it finally will give up and take all your orders just like from a dictator, so im pretty sure there is some very deep mental programming at work here, and as I mentioned, churches worldwide may do the same thing, christian catholic church at least for sure.
so...
Now the problem here: we are not bad. we are beautiful, proud, great, and no fucking slaves, we are all that is magic and even more, we are gods and even more.
But media tells us we are bad, we pollute the environment, while the market leaders and the guys who sustain this profit bases monetary system. Its nothing more than money and so called economics that pollute the world. Where clean and good technology being fought or forbidden, just to ensure everything stays as it is.
And giving your guys out there, all people of the world the feeling, the notion of being responsible for all this, is just the fucking best way to just pertain this whole system.
Now many of you might not consider working on those high levels (or call them low or deep levels if you want) of human relations. But actually there are very intelligent and powerful men out there, who never have to spend a thought about where to get their next meal, and they have time to think about how they can expand their power, they know how religion works, how media works and ultimately they know how to control people, as control is power.
Unfortunately they dont know that all this does not fulfill them, but I know what would, which gives me some power ;) but I would never abuse it.
Anyways. All this leads to people like Chris, and trust me I know many many, especially in germany many of those, who just feel and behave like beaten dogs, with almost automatic exressions like "we are bad, planet would be better without us" bla bla bla
sorry chris, get your shit together, we are good, proud, and with the wille zur macht we can also get rid of those assholes who infect our bodies our minds and our economy! its an infection, earth has a virus, its called banking system, or profit system. infection and perversion started there and settled over to our minds, all that is wrong or "evil" is being able to traced back to some financial techniques, most notably "interest" which already the superhero jesus is said to have condemned it...
Feel free to watch ZEITGEiST 3
http://www.youtube.com/watch?v=4Z9WVZddH9w
It surely explains a huge lot, but not all..
siriusbliss
Post by siriusbliss »
My 3-Scope-card DAW heats my studio so that I don't have to turn on the heater, or wear extra clothes - literally.
My network connection with collaborators around the world saves me time, money, and pollutants having to drive/fly somewhere.
Seems to me my Scope cards are actually helping the environment.
ChrisWerner
Well, I know me and I say I am good. I don't know most of you, so I can't and never would tell what you are.
Sure we are good on planet. The planet meets the other thing is just a joke that gives me a smile, that's it.
Methane Hydrate is down there, if you want it or not. Just a fact I shared here, open for discussion.
I saw Zeitgeist and I saw other things, I see people every day saying something and sometimes I tell something, too.
That's it. Time for breakfast :-)
yeah, Zeitgiest is really the same clowns coming from another direction(their ultimate solution is to let the "wise elite" "reeducate" the masses), but i like the general thought about the way control works. the Devil will always tell the truth, if he can lead one astray through it.
Chris, i never thought that you were messed up in your thinking, just the joke, which is funny. :lol:
Dusty, i'm down with your last post, except for the end part when you become cooler than everyone else, who get bloodied by some reductio ad absurdum conclusion.
wow, what a silly thread....
